spindle won't reverse
06 Oct 2024 20:54 #311444 by foam man
spindle won't reverse was created by foam man
HI
Does anyone have any knowledge about Probotix? I have a CNC control box from them and I plugged my regular 120v drill press into the router port. I can make it turn on and off but the speed will not change and when I hit reverse it does nothing.
06 Oct 2024 21:43 #311448 by tommylight
Replied by tommylight on topic spindle won't reverse
This is a stab in the dark, but drill motors are usually induction types with a capacitor, so they do not reverse without rewiring.
What type of motor did the probotix use?
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
07 Oct 2024 14:36 #311494 by Todd Zuercher
Replied by Todd Zuercher on topic spindle won't reverse
The router motor that the Probotix box would have used would not have been able to reverse either. Regular routers that plug into a house hold outlet are one way only also. (Often using brushed universal motors.)
11 Oct 2024 04:08 #311793 by foam man
Replied by foam man on topic spindle won't reverse
i'm not sure what motor they use as I just have the Probitix box
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
11 Oct 2024 16:24 #311818 by Todd Zuercher
If the Probotix box has just a household outlet to plug in the "spindle or router" it would almost certainly be just an ordinary consumer home router motor.
Time to create page: 0.106 seconds
