Clippard stepper motor with TB6552FNG
  • selizer@actalentservices.com
  • New Member
  • New Member
08 Oct 2024 14:36 - 08 Oct 2024 14:40 #311576 by selizer@actalentservices.com
Clippard stepper motor with TB6552FNG was created by selizer@actalentservices.com
Hello team i'm using clippard motor with TB6552FNG
connection diagram i have attached below.
I'm able to see the stepper motor running but im not able to control the motor
Can you please send the exaple code for this TB6552FNG to control the motor
Last edit: 08 Oct 2024 14:40 by selizer@actalentservices.com.
  • Moderator
  • Moderator
10 Oct 2024 22:46 #311783 by tommylight
Replied by tommylight on topic Clippard stepper motor with TB6552FNG
toshiba.semicon-storage.com/info/TB6552F...1&prodName=TB6552FNG
Functionally the same as L298, so there should be a config included with LinuxCNC that uses a parallel port to control 2 motors, probably named "etch a sketch" or similar, use that config if you have a PC parallel port, or modify it to suit your needs.
Time to create page: 0.050 seconds
