not getting the signals to the pins
  • TheProcessTechnician
  • New Member
  • New Member
10 Oct 2024 15:01 - 10 Oct 2024 15:02 #311737 by TheProcessTechnician
not getting the signals to the pins was created by TheProcessTechnician
Hi there!
Total newbie here. I cant get the LinuxCNC signals to the Pins, I am getting following error:
Linux parallel port 0 not found
hal_parport: rtapi_app_main: No such file or directory (-2)
if I am trying to set up the pins in the terminal following happens:
halcmd: loadrt hal_gpio outputs=GPIO13,GPIO19
Note: Using POSIX realtime
The GPIO line GPIO13 can not be found
hal_gpio: rtapi_app_main: Operation not permitted (-1)
<stdin>:6: waitpid failed /usr/bin/rtapi_app hal_gpio
<stdin>:6: /usr/bin/rtapi_app exited without becoming ready
<stdin>:6: insmod for hal_gpio failed, returned -1
What am I doing wrong?
Setup:
Raspi5
LinuxCNC 2.9.1
Milling machine BADOG Cubique
Driver: Badog CNC MikroNC
me (Noob, LinuxCNC beginner)
configuration with Stepconfwizard
GPIO Pins are directly connected to the Driver (should work according to BADOG)
Changes in the .hal file:
#net estop-out       => parport.0.pin-01-out
net xdir            => hal_pi_gpio.pin-13-out
net xstep           => hal_pi_gpio.pin-19-out
setp hal_pi_gpio.pin-19-out-reset 1
net ydir            => hal_pi_gpio.pin-05-out
net ystep           => hal_pi_gpio.pin-06-out
setp parport.0.pin-05-out-reset 1
net zdir            => hal_pi_gpio.pin-27-out
net zstep           => hal_pi_gpio.pin-22-out
setp hal_pi_gpio.pin-22-out-out-reset 1
net adir            => hal_pi_gpio.pin-04-out
net astep           => hal_pi_gpio.pin-17-out
setp hal_pi_gpio.pin-17-out -reset 1
#net spindle-cw      => parport.0.pin-14-out
#net spindle-pwm     => parport.0.pin-16-out
#net xenable         => parport.0.pin-17-out
Report file attached.
Last edit: 10 Oct 2024 15:02 by TheProcessTechnician.
10 Oct 2024 15:09 #311738 by tommylight
Replied by tommylight on topic not getting the signals to the pins
WTH?
Is that a PC or RPI?
hal_parport = does not work on RPI, it is for PC with parallel port
hal_gpio = does not work on PC, it is for RPI pins
  • New Member
  • New Member
10 Oct 2024 15:19 #311740 by TheProcessTechnician
Replied by TheProcessTechnician on topic not getting the signals to the pins
Its a RPI, as stated in the setup.
I dont need the spindle or the estop, so i didnt change them and commented them out.
  • New Member
  • New Member
10 Oct 2024 15:27 #311743 by TheProcessTechnician
OMG, I am stupid, half of the .hal file is still filled with hal_parport commands... can i just replace hal_parport with hal_gpio?
but it still doesnt solve the problem of the try in the terminal.
10 Oct 2024 15:29 #311744 by tommylight
OK, remove hal_parport from the hal file, although that might not fix your issues as hal_gpio errors out with permission denied, and there i can not help as i do not use RPI.
The following user(s) said Thank You: TheProcessTechnician
  • New Member
  • New Member
10 Oct 2024 16:30 #311751 by TheProcessTechnician
thank you sir, I solved the hal_parport problem, but i still got the permission denied. tried to add user to the group with adduser and gpasswd, sadly no result. anybody got a solution to the problem? error output:
The GPIO line GPIO4 can not be found
Time to create page: 0.168 seconds
