LMDE6 problem-----> (SOLVED)
- PhilipME
- Thank you received: 14
12 Oct 2024 16:38 - 13 Oct 2024 03:45 #311883
by PhilipME
LMDE6 problem was created by PhilipME
I installed LMDE6. The installation wizard give me a message that installation is complete.
But when I boot, the process goes straight to windows. Linux not even in the bootable devices.
During installation. the wizard force me to create a partition for the grub. But I think windows boot manager takes over and no any sign that LMDE6 exist.
Any body came across this problem ?
EDIT: I tried this solution but still not working
linuxmint-installation-guide.readthedocs...atest/multiboot.html
Good day
Philip
Good day
Philip
Last edit: 13 Oct 2024 03:45 by PhilipME.
- PhilipME
13 Oct 2024 18:52 #312001
by PhilipME
Replied by PhilipME on topic LMDE6 problem-----> (SOLVED)
If any one face the issue described in this thread, make sure when you create the image to use GPT partition scheme. Should not use MBR partition scheme
Good day
Philip
Good day
Philip
Time to create page: 0.093 seconds
