hal logic for Tool length sensor and touch probe with Mesa 7i96
- kbec
- Thank you received: 4
12 Oct 2024 18:41 #311887
by kbec
hal logic for Tool length sensor and touch probe with Mesa 7i96 was created by kbec
If I recall correctly, I need to have both the probe and tool length sensor linked with a or in my hal file to work properly.
I currently have my ground going into "IN COMMON", the probe connected to "IN 8" and the tool length sensor going into "IN 9". The probe and sensor are wired correctly because when triggered, the led on the 7i96 and the probe lights come on.
I believe I need an or going into the probe-in, currently I have:
grep probe *.hal
MillXYZQTDragon.hal:net probe-in <= hm2_7i96.0.gpio.008.in
MillXYZQTDragon.hal:# ---probe signal---
MillXYZQTDragon.hal:net probe-in => motion.probe-input
How do I set the or piece? I think I will need to add it each time I redo my PNCCONF, as it will probably be overwritten. I think I had it working a while back and that is what happened to it.
Thanks in advance
grep probe *.hal
Thanks in advance
- Thank you received: 7488
24 Oct 2024 22:50 #313165
Replied by tommylight on topic hal logic for Tool length sensor and touch probe with Mesa 7i96
Start here and continue on
forum.linuxcnc.org/38-general-linuxcnc-q...ith-mesa7i76e#124688
Edit card name accordingly.
Time to create page: 0.082 seconds
