Control feed speed with a potentiometer
- jacgri24
13 Oct 2024 12:41 #311961
by jacgri24
Control feed speed with a potentiometer was created by jacgri24
Hello,
i want to control the feed speed with a potentiometer on a 7i96s mesacard.
i dont know how to do that.
Can anybody explain me, what i have to do?
Thanks in advance.
Thanks in advance.
- Deckerjwd
- Thank you received: 3
13 Oct 2024 15:22 #311976
by Deckerjwd
Replied by Deckerjwd on topic Control feed speed with a potentiometer
you probably could add a 7i84 to get a few analog inputs, then link them in the Hal to feed override. you would have to hook it up to the serial port on your 7i96s. there would be a lot to consider for the HAL, but think there some math components that should work, would want a 36v power supply to use the full scale
The following user(s) said Thank You: jacgri24
- Thank you received: 5330
13 Oct 2024 16:16 #311979
Replied by PCW on topic Control feed speed with a potentiometer
A 7I73 will work as well (and is 3.3V full scale)
Time to create page: 0.130 seconds
