New minor problem
16 Oct 2024 18:37 #312286 by acourtjester
New minor problem was created by acourtjester
I am having a very minor problem with a routine I have use for some time with other software. That is to set the router bit a known height above the surface of the material.  I think it is just a setting that I need to change in the setup in Pnnconf for the GIU.  I have attached a PDF with a description and screen shots showing what is happening.  And the G-code that does exactly what I want.
Thanks again for you time and help.
Tom
This browser does not support PDFs. Please download the PDF to view it: Download PDF
File Name: Ohmiczerom...xCNC.ngc
File Size:0 KB
22 Oct 2024 13:53 #312858 by bkt
Replied by bkt on topic New minor problem
you mix "Z" and"z" than "z      0.4" and "z0.2" ... try to adjust these spaces from z to number on ngc code .... after maybe you have not enought z spaces on negative limit (for some offset for example)  ..... you check these?
23 Oct 2024 00:46 #312921 by acourtjester
Replied by acourtjester on topic New minor problem
THANKS I increased the Z travel distance to 7" and that seems to have cured the problems. I did not get the errors and I an repeat the surface detection over again with out a error too.
23 Oct 2024 17:20 #312987 by bkt
happy for you .... nice
Time to create page: 0.080 seconds
