Holes have a taper
- Deckerjwd
- Thank you received: 3
23 Oct 2024 14:47 #312972
by Deckerjwd
Replied by Deckerjwd on topic Holes have a taper
you maybe reaching the tolerance that MDF can hold, while MDF is More Stable than other woods it still changes shape massively compared to metals and some plastics. i will try to run some holes on my phantom s4. it does many small move like your, I suspect I will get the similar results as you. that would mean tool deflection and/or material movement
- sajurcaju
- Thank you received: 10
23 Oct 2024 14:50 #312974
by sajurcaju
Replied by sajurcaju on topic Holes have a taper
Well that I hadn't thought of. I'll be very interested in your results.
- Deckerjwd
18 Jan 2025 16:47 #319296
by Deckerjwd
so i have had trouble holding that close of a tolerance, my holes are strait but the size is +-/0.003 with it tending toweds the small size. i can sneek up on it but not worth it for what we run on the phantom. may stick some wood in the mazak vtc-20 and run blind pocket and probe it
