7i92+7i77 basic comms again
- 3CHman
- Banned
19 Oct 2024 15:02 #312611
by 3CHman
7i92+7i77 basic comms again was created by 3CHman
Hi Guys - 7i92+7i77 combo. Sorry to have to seek help so early in my project. Im trying to take it all step by step but hit a brick wall with the comms to the 7i77. It isnt being recognised by the the 7i92. I just have the boards on the bench powered from a lab power supply at the mo. I'm just using mesaflash on 192.168.1.121 with the basic linuxcnc - no realtime yet - and flashed with 7i92+7i77X2D.bin all seems OK but when I use --sserial --verbose or --readhmid there is no mention of the 7i77. I have the two cards directly connected with their X25Dshell's - no cable - and +12V Field.
LED's - On the 7i92 Ive got the +5V LED and variously some of the user LED's lit (these vary when I interogate the card - bit odd) and on the 7i77 LED's - +5V,Field Voltage,CR15 Field Activity, and CR16 Field I/O fault which is Red. All these LED's permanently on. Worryingly LED 6 and 7 are not on - in the manual there are +16V and -12V monitors and should be on??
Should basic comms be working as above or should I have some ini or hal commands to get things going.
Thanks for all your help...
- Thank you received: 7488
19 Oct 2024 15:09 #312613
Replied by tommylight on topic 7i92+7i77 basic comms again
There should be no red leds on.
Picture?
Picture?
- Thank you received: 5330
19 Oct 2024 15:25 #312615
Replied by PCW on topic 7i92+7i77 basic comms again
Sounds like you have both 7I77 processors in setup mode
That will not work, they must be in operate mode:
W4 and W12 in left hand position
- 3CHman
- Banned
19 Oct 2024 17:48 #312628
by 3CHman
Replied by 3CHman on topic 7i92+7i77 basic comms again
Yup..you have nailed it. Many thanks both. Operate mode it now is - crash on to the next phase!
Thanks again
Thanks again
