About lathe spindle encoder
- The Egyptian
- Topic Author
2 years 1 week ago #312729
by The Egyptian
About lathe spindle encoder was created by The Egyptian
Hi , is there any way to connect encoder to arduino to count encoder pulses and send the count to linuxcnc
i want to use 2000ppr encoder so i want to use arduino insted of pc to count pulses
any help will be appreciated
2 years 1 week ago #312766
Replied by tommylight on topic About lathe spindle encoder
What RPM?
There is a project here using ESP32 in wireless mode for spindle encoder counting that works very well as described by the maker,
github.com/futurelink/linuxcnc-spindle-encoder
If you do have a high RPM spindle, do not bother with it as Arduino will not be able to count, for a 24000RPM with 2000PPR encoder you will have to count 3200000 counts per second or 3.2MHz !
Using interrupts in arduino might just get to count up to 1MHz, but that would be really pushing it.
- The Egyptian
- Topic Author
2 years 1 week ago #312837
by The Egyptian
Replied by The Egyptian on topic About lathe spindle encoder
thanl you for replay , but i want to use arduino with 600ppr encoder can i
2 years 1 week ago #312850
What is the spindle speed?
- The Egyptian
- Topic Author
2 years 1 week ago #313025
by The Egyptian
spindle speed 2000-2500 rpm
2 years 1 week ago #313056
2500rpm/60sec=41.66RPS
600PPR*4=2400counts per revolution
41.66*2400=100000 counts per second.
It should work as long as you use the interupts in arduino, so no "digital_read" in the code.
- The Egyptian
- Topic Author
2 years 1 week ago #313086
by The Egyptian
My problem is how to write hal configuration for this operation i'm fimilier with arduino code but i'm new to linuxcnc can you help me with hal config
2 years 1 week ago #313091
- Thank you received: 5334
2 years 1 week ago #313092
Replied by PCW on topic About lathe spindle encoder
How do you intend to send the count and control signals to the PC?
- The Egyptian
- Topic Author
2 years 1 week ago #313122
by The Egyptian
i'm trying to do my best but i hope to find some help here
all i want is to read encoder away of pc becouse parallel port is too slow
i'm trying to use arduino becouse it's the only hardware available in my country , i built a cnc lathe it works very good but when i do some thread the encoder read well in slow speed under 500rpm but when speed up the encoder out of rang and the machine stops
any help on this case
Time to create page: 0.280 seconds
