Parallel SCARA Kinematics - Closed Loop
22 Oct 2024 20:24 - 22 Oct 2024 20:28 #312893 by olzy
https://photos.app.goo.gl/AMjtLChLGqvqSN6NAHi there,
I have made a 5 bar robot, often referred to as a Parallel SCARA machine. For this I have used harmonic gearboxes. The machine is used for CNC plasma cutting.
Currently I am using RepRap firmware to control the machine. I have a tiny amount of backlash in one of my harmonic gearboxes, I have tried replacing the gearbox but the units are fairly cheap and the issue is still there. I would like to add either closed loop control or backlash compensation to the joints, which is not possible to do within RepRap firmware.
I have been looking through the scarakins within LinuxCNC and was hoping someone may be able to let me know if the following is possible?
- Run a parallel SCARA machine in LinuxCNC
- Apply Closed Loop control to actuated joints
- Apply backlash compensation to actuated joints
I have a CNC mill using LinuxCNC so have some understanding of linuxCNC and really enjoy using it. Please let me know any thoughts.
Kind regards
Olzy
Last edit: 22 Oct 2024 20:28 by olzy.
23 Oct 2024 06:39 #312925 by Aciera
Replied by Aciera on topic Parallel SCARA Kinematics - Closed Loop
See here, has not published the kinematic though:
Closed loop for the motors is not a problem.
Backlash compensation is possible in linuxcnc but don't expect it to make the problem go away completely as the PID loop will have it's problems coping.
Time to create page: 0.215 seconds
