Double / twin scara robot
- Stanislavz
- Thank you received: 18
23 Oct 2024 10:28 #312938
by Stanislavz
Double / twin scara robot was created by Stanislavz
Hello. Is it possible to configure linuxcnc for two scara x/y and u/z axis from same controller ? Ie - i would like to make a cnc foam cutter, and have independednt sides controlled from same controller for tapered cuts. .
- Thank you received: 7488
23 Oct 2024 10:48 #312940
Replied by tommylight on topic Double / twin scara robot
Scara is a certain type of robot arm, usually with 4 or 5 joints/axis, not a foam cutter.
Yes, it can do indepent axis foam cutter, i have made several of them, and it can have configurations for 2 axis with 4 joints or tandem and a configuration for independent 4 axis, even 5 is you want to add a rotary table.
Some examples
www.google.com/search?q=foam%20cutter%20...%20cutter%20linuxcnc
Some examples
The following user(s) said Thank You: Stanislavz
- Stanislavz
23 Oct 2024 11:07 - 23 Oct 2024 13:03 #312943
by Stanislavz
Replied by Stanislavz on topic Double / twin scara robot
Some examples
Thank you for reply, by meaning scara - i do have in mind to replace two linear rails with two steppers and some gears on it. For each side. For smaller one it is ok to have 1:4 gear ratio to have ok resolution for foam cutter. With 8 microstep it shell give0.1227mm step~0.5mm at 500mm arm radius.
I have made mre than one foam cutter and i do hate to drag it around. Scara would be wery compact then not used.
Last edit: 23 Oct 2024 13:03 by Stanislavz.
Time to create page: 0.199 seconds
