change the ini with the axis interface open
30 Oct 2024 01:02 #313466 by Thayloreing
change the ini with the axis interface open was created by Thayloreing
Is there any way to create a button to select two different accelerations? example
my machine has an acceleration of 1000ms2 in the ini file, I want to create a button in the axis interface that when I press it changes the acceleration to 500, so I can work with heavy parts more smoothly without having to change it manually
  • Moderator
  • Moderator
30 Oct 2024 01:54 #313468 by tommylight
The following user(s) said Thank You: Thayloreing
06 Nov 2024 13:00 #313894 by Thayloreing
Replied by Thayloreing on topic change the ini with the axis interface open
Is there a way to change the acceleration while the program is running? I tried to use m68 to change the acceleration during the program, but the planner ignores the change commands, but when I only run m68 it changes the acceleration as I determine.
  • Moderator
  • Moderator
06 Nov 2024 14:04 #313908 by tommylight
Replied by tommylight on topic change the ini with the axis interface open
Pretty sure it was discussed here recently, have a look at "recent topics" on the forum menu.
06 Nov 2024 15:42 - 06 Nov 2024 15:43 #313917 by Aciera
Replied by Aciera on topic change the ini with the axis interface open
Changes to the ini.* halpin values during Gcode execution will only take effect after a 'queuebuster' command (eg 'M66 E0 L0') in the gcode. A queuebuster is a command that stops and reinitializes the interpreter with the current ini.* pin values . M68 alone does not cause such a synchronization.
Last edit: 06 Nov 2024 15:43 by Aciera.
The following user(s) said Thank You: zack, Thayloreing
Time to create page: 2.510 seconds
