Initial height sensing for underwater cutting tourqe sensing
- tcbmetalworks
- Thank you received: 21
30 Oct 2024 06:04 #313471
by tcbmetalworks
Initial height sensing for underwater cutting tourqe sensing was created by tcbmetalworks
Hello what are some methods to make initial height sensing work for underwater cutting. I am using a hypertherm ht2000 with a pneumatic breakaway so I would like toavoid modifying it to floating head. Is it possible to accurately use tourqe sensing to determine the top of the plate when plasma cutting?
- Thank you received: 7488
30 Oct 2024 13:03 #313482
Replied by tommylight on topic Initial height sensing for underwater cutting tourqe sensing
Depends on what system is used on Z, steppers can not do torque sensing (even TMC drives miss that a lot), servos can do that but in most cases they would require opening the drive and soldering extra wires as not all have monitoring outputs.
The easiest way, floating head, and it does not miss.
- tcbmetalworks
31 Oct 2024 06:13 #313527
by tcbmetalworks
Replied by tcbmetalworks on topic Initial height sensing for underwater cutting tourqe sensing
Yes I am thinking the floating head will be the way to go I was thinking to build it spring loaded or with a adjustable pnumatic spring so that it could be adjusted to cancel out the weight of the torch.
Time to create page: 0.175 seconds
