- LinuxCNC
- General LinuxCNC Questions
- How to add a PCI card paralell and serial ports to an ASUS pc for debian linuxc
- martyop
01 Nov 2024 01:19 - 01 Nov 2024 01:19 #313562
by martyop
How to add a PCI card paralell and serial ports to an ASUS pc for debian linuxc was created by martyop
I installed a PCI serial/parallel port card in an old ASUS pc to run CNC linux, latest debian version.
The computer did not have a native parallel port.
The program does not find the new pci parallel port. How may I troubleshoot that?
Or can someone recommend a parallel port card that does work?
Thanks very much.
Thanks very much.
Last edit: 01 Nov 2024 01:19 by martyop.
- Thank you received: 7478
01 Nov 2024 03:01 #313566
The following user(s) said Thank You: martyop
- martyop
02 Nov 2024 02:20 #313638
by martyop
Replied by martyop on topic How to add a PCI card paralell and serial ports to an ASUS pc for debian linuxc
Thanks,
I will check that out.
- LinuxCNC
Time to create page: 0.212 seconds
