xml tool Table
- Deckerjwd
- Thank you received: 3
01 Nov 2024 15:48 #313605
by Deckerjwd
xml tool Table was created by Deckerjwd
want to use HSM Advisor to manage my tools it has a xml export, is there a linuxcnc converter or xml plugin ?
- Thank you received: 2176
01 Nov 2024 18:03 #313611
Replied by Aciera on topic xml tool Table
I'm not aware of an XML import.
It is possible to use an external database for tool management:
linuxcnc.org/docs/devel/html/tooldatabase/tooldatabase.html
As an alternative it might be possible to convert the xml tool data to ordinary list data used in linuxcnc (eg by a custom python script):
linuxcnc.org/docs/devel/html/gcode/tool-....html#sec:tool-table
Time to create page: 0.092 seconds
