Carte d'adaptateur PCI Express vers parallèle DB25
- jfwillem
02 Nov 2024 18:25 #313671
by jfwillem
Carte d'adaptateur PCI Express vers parallèle DB25 was created by jfwillem
bonjour, je voudrais savoirsi la carte
bonjour, je voudrai savoir si une carte d'adaptateur PCI Express vers parallèle DB25 peut etre utilisee pour linuxcnc? merci
fr.aliexpress.com/item/1005007091741451....gatewayAdapt=glo2fra
- Thank you received: 7488
03 Nov 2024 01:43 #313688
Replied by tommylight on topic Carte d'adaptateur PCI Express vers parallèle DB25
There is no way of knowing if it works or not without actually testing it, there are to many types of them out there.
I can not read the chip type used, it might help to find out if someone here has used it.
I have used plenty of MOSCHIP or NETMOS ones in PCI version and they all worked, but PCI-E i have not used.
Time to create page: 0.193 seconds
