LinuxCNC Error
05 Nov 2024 06:23 #313796 by Micro2000
LinuxCNC Error was created by Micro2000
I have 2.9.3 with the 5.4.258 RTAI kernal and am getting an error when starting my mill program.
     insmod: ERROR: could not load module /usr/realtime-5.4.258-rtai-amd64/modules/rtai_hal.ko: no such file or directory
05 Nov 2024 12:30 #313812 by tommylight
Replied by tommylight on topic LinuxCNC Error
Do you also have the RTAI version of LinuxCNC? It seems you do as the .ko should be RTAI and .so should be Preempt.
Paste the full error report here, please.
05 Nov 2024 16:22 - 05 Nov 2024 16:23 #313824 by Micro2000
Replied by Micro2000 on topic LinuxCNC Error
After I got the error and copied that specific part the error changed it won't come back again.
How would I get an RTAI version of linuxcnc, I have been looking at the getting started and installing linuxcnc and haven't seen anything like that.
I am so confused right now because the documentation has instructions but it seems like packages are missing from the pre-made files, and the documentation that is stated does not work. Then when I go to forums I am being told that some things may be missing. I am so lost right now, I don't know what to follow and what to ignore, out of date info, what files do and don't work with each other...etc.
Last edit: 05 Nov 2024 16:23 by Micro2000.
05 Nov 2024 17:02 #313831 by tommylight
Normally after installing the 2.9.3 ISO, you should do
sudo apt purge linuxcnc-uspace
sudo apt install linuxcnc
then after reboot hold down the shift keys till you get the GRUB menu, there choose advanced options and select the one with RTAI in the name, enter.
Did you do this last step before testing?
05 Nov 2024 21:19 #313854 by Micro2000
I never seen any documentation saying to use those commands in that way. I will try that and get back to you.
06 Nov 2024 02:05 #313867 by Micro2000
when I run "sudo apt install linuxcnc" it returns
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package linuxcnc is not available, but is referred to by another package.
This may mean that the package is missing, has ben obsoleted, or is
only available from another source
E: Package 'linuxcnc' has no installation candidate
06 Nov 2024 04:38 #313870 by Micro2000
Maybe it will work but I am going to try the file from the downloads page at the LinuxCNC Packages "LinuxCNC package for RTAI Kernal 5.4.258" the file is labeled as "linuxcnc_2.9.3_amd64.deb"
06 Nov 2024 13:25 #313897 by tommylight
Not sure what changed in 2.9.3, vut that was the procedure for 2.9.1 i think.
Let us know if it works.
Thank you.
06 Nov 2024 15:31 - 06 Nov 2024 15:39 #313916 by Micro2000
Do you know how you would install the linuxcnc package? I thought I knew, but I wasn't able to accomplish it.
Last edit: 06 Nov 2024 15:39 by Micro2000.
06 Nov 2024 17:50 - 06 Nov 2024 17:50 #313931 by tommylight
Last edit: 06 Nov 2024 17:50 by tommylight.
Time to create page: 0.133 seconds
