LinuxCNC Error
1 year 11 months ago #313870 by Micro2000
Replied by Micro2000 on topic LinuxCNC Error
Maybe it will work but I am going to try the file from the downloads page at the LinuxCNC Packages "LinuxCNC package for RTAI Kernal 5.4.258" the file is labeled as "linuxcnc_2.9.3_amd64.deb"
1 year 11 months ago #313897 by tommylight
Replied by tommylight on topic LinuxCNC Error
Not sure what changed in 2.9.3, vut that was the procedure for 2.9.1 i think.
Let us know if it works.
Thank you.
1 year 11 months ago - 1 year 11 months ago #313916 by Micro2000
Do you know how you would install the linuxcnc package? I thought I knew, but I wasn't able to accomplish it.
Last edit: 1 year 11 months ago by Micro2000.
1 year 11 months ago #313988 by Micro2000
I am getting this error when I try to install the main package
sudo apt-get install '/home/dylan/Downloads/linuxcnc_2.9.3_amd64.deb'
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'linuxcnc' instead of '/home/dylan/Downloads/linuxcnc_2.9.3_amd64.deb'
The following packages were automatically installed and are no longer required:
  libgpiod2 python3-serial python3-yapps
Use 'sudo apt autoremove' to remove them.
Suggested packages:
  onboard
The following NEW packages will be installed:
  linuxcnc
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/25.5 MB of archives.
After this operation, 89.9 MB of additional disk space will be used.
Get:1 /home/dylan/Downloads/linuxcnc_2.9.3_amd64.deb linuxcnc amd64 1:2.9.3 [25.5 MB]
(Reading database ... 185376 files and directories currently installed.)
Preparing to unpack .../linuxcnc_2.9.3_amd64.deb ...
Unpacking linuxcnc (1:2.9.3) ...
dpkg: error processing archive /home/dylan/Downloads/linuxcnc_2.9.3_amd64.deb (--unpack):
 trying to overwrite '/usr/share/applications/linuxcnc-documentation.desktop', which is also in package linuxcnc-doc-en 1:2.9.3
Errors were encountered while processing:
N: Download is performed unsandboxed as root as file '/home/dylan/Downloads/linuxcnc_2.9.3_amd64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
E: Sub-process /usr/bin/dpkg returned an error code (1)
1 year 11 months ago #313995 by tommylight
sudo gdebi linuxcnc_2.9.3_amd64.deb
In the same folder where the downloaded files are.
Time to create page: 0.252 seconds
