New basic setup recommendations
- Routerworks
- Thank you received: 14
10 Nov 2024 19:09 #314201
by Routerworks
New basic setup recommendations was created by Routerworks
I have been using linuxcnc for a few years now with a much older Dell dimension e521 computer with an installed parallel port card. Worked great, very satisfied. Recently it decided not to boot, no power to keyboard or mouse. Changed cmos battery but still won't get past "Dell" logo. No response to keyboard. Think it's time to replace whole system.
Looking for a used computer perferably with a parallel port or at least a slot for one. Possibly should converto to ethernet card such as "Mesa 7I96" or something close.
Fortunately I copied by filling setup folder with working ini and hal files.
My question are as follows:
1.) Should I upgrade to a newer version of linuxcnc (using 2.8...)?
2.) I have a new all in one desktop with an ethernot port. Can't add parallel port. Do ethernet to parallel port adapters work without timing issues?
3.) What is a stable version to upgrade to (all in one install) or should I stay with my older version? Is there much gain as it seemed to be working fine.
4.) Can I use the same ini and hal files with a newer version or do I have to do a whole new setup. Trying to avoid that as dual Y steppers was a hastle and now I want to add a 4th A axis.
Any comments would be greatly appreciated from those much more experienced at this than myself.
Regards,
Routerworks
Regards,
Routerworks
- Thank you received: 7488
10 Nov 2024 20:17 #314208
Replied by tommylight on topic New basic setup recommendations
1. No.
2. Yes bit to complicated, and do not buy those ebay stuff at over 80$ as that is Mesa price and Mesa is much, much better.
3. 2.9.3 but i would stick with Wheezy and 2.7 for parallel port.
4. Yes, rarely might need editing. Granted no special comps/features were in use.
- Routerworks
11 Nov 2024 17:20 #314265
by Routerworks
Replied by Routerworks on topic New basic setup recommendations
Thank you all. I think I'll try to resurect what I have and stick with the present version. It works.
Should I have to get a new computer (decent used one) will the 7I76 board allow me to connect the drivers directly to it or do I need another board?
Thanks again
Thanks again
- Thank you received: 5330
11 Nov 2024 18:01 #314267
Replied by PCW on topic New basic setup recommendations
A 7I96 or 7I96S are stand-alone
(a 7I76 needs an additional FPGA card)
- Routerworks
11 Nov 2024 23:44 #314290
by Routerworks
Thank you for your generous offer. I was able to get it to boot up with 3 of the ram cards removed. Will see if replacing them will work as well. I am in Florida, USA.
Are you in this country?
Thanks again,
Routerworks
Thanks again,
Routerworks
- Routerworks
14 Nov 2024 14:05 #314445
by Routerworks
Think it might be time to ditch it. I reinstalled linuxcnc and it loads properly however I get a bios 8254 error when loading, also "not connected to IO-APC".
From what I have read this could be a timing issue caused by a faulty timing chip on the mother board. How far do you go with a 15 year old computer?
There a lot of old Optiplex computers on the market for under $100.00 that are far more powerful and way exceen the minimum requirements for linuxcnc. I would only have to install the parallel port I could take out of the old one.
Any suggestions are apppreciated before I scrap it.
Many thanks for all you help.
14 Nov 2024 14:45 #314451
Dell Optiplex 760 (very old Core2Duo) and 980 (older i5) have parallel ports in Tower cases, both work good with LinuxCNC for software stepping and 980 is good for Mesa.
HP Z210, Z220, Z230 should all have a parallel port header and usually come with the adapter/port in, also very good for LinuxCNC and built like tanks.
Some Fujitsu i5 and i7 are also very good, but no idea what models they vere, and i have a Fujitsu laptop that is very good for Mesa, unfortunately gave it to a client and got it back with a broken screen.
As for laptops, i have bought several older Lenovo laptops and strangely most are ok for Mesa use, example X220 and T420S were unusable, X240 seems OK from some short testing! A T470 i have in use for over 6 months on a production machine, works fine with Mesa 7i92.
There are several topics here on the forum with plenty of used PC/laptops tested with LinuxCNC for Mesa and parallel port, but as with everything, yout milage may vary, as i had two of the same Acer laptops where one was very good and the other was terrible for latency, the only difference was CPU i think.
- Routerworks
14 Nov 2024 14:58 #314454
by Routerworks
Thanks a lot, I'll check it out. Do you think running with this error message is risky?
14 Nov 2024 15:12 #314455
Should not affect work/use, LinuxCNC is very good at reporting issues, so if LinuxCNC is not complaining, move on, all is good.
- Routerworks
14 Nov 2024 15:14 #314456
by Routerworks
Thanks again.
Time to create page: 0.139 seconds
