Linuxcnc crashing randomly when pressing buttons
- domse
11 Nov 2024 18:23 - 11 Nov 2024 18:24 #314269
by domse
Linuxcnc crashing randomly when pressing buttons was created by domse
Hello, so this same problem occurs on on two different machines. One is an old core 2 duo pc + mesa 7i96 with monitor, keyboard, mouse. The other one is a raspberry pi 4 + 7i96s with a vnc connection (no monitor, no mouse, no keyboard) running a plasma machine.
Randomly the program crashes when navigating the gmocappy gui. it happens while jogging in small increments, when switching to program mode, when searching for a gcode file. I'd say the raspberry crashes more often than the pc. When i manage to start a gcode file, even if it is hours long, it is stable.
i attached a report below, this time the machine was homed and the y axis was moved in small increments when it crashed.
Report:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.4
Machine configuration directory is '/home/pi/linuxcnc/configs/plasma'
Machine configuration file is 'plasma.ini'
INIFILE=/home/pi/linuxcnc/configs/plasma/plasma.ini
VERSION=1.1
PARAMETER_FILE=metric_parameters.txt
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYYZA
KINEMATICS=trivkins coordinates=XYYZA kinstype=BOTH
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./plasma.hal
twopass:found ././plasmac/plasmac.tcl
twopass:found ./plasma_connections.hal
Starting DISPLAY program: gmoccapy
task: main loop took 0.141396 seconds
task: main loop took 2.166802 seconds
33554435
41943043
37748739
35651587
39845891
31457283
44040195
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
(0, ' = ', '/usr/bin/gmoccapy')
(1, ' = ', '-ini')
(2, ' = ', '/home/pi/linuxcnc/configs/plasma/plasma.ini')
Entry = trivkins
Entry = coordinates=XYYZA
found the following coordinates xyyza
Entry = kinstype=BOTH
**** GMOCCAPY GETINIINFO ****
Number of joints = 5
5 COORDINATES found = xyyza
('Fount double letter ', )
joint 0 = axis x
joint 1 = axis y0
joint 2 = axis y1
joint 3 = axis z
joint 4 = axis a
{0: 'x', 1: 'y0', 2: 'y1', 3: 'z', 4: 'a'}
[KINS] KINESTYPE is trivkins
Found kinstype=BOTH but using trivkins
It is not recommended to do so!
Will use mode to switch between Joints and World mode
hopefully supported by the used <<trivkins>> module
No MAX_RAPID_OVERRIDE entry found in [DISPLAY] of INI file
Default settings 100 % applied!
Preference file path: /home/pi/linuxcnc/configs/plasma/Plasma.pref
No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file
**** GMOCCAPY INFO ****
**** no valid probe config in INI File ****
**** disabled tool measurement ****
**** Entering make_DRO
axis_list =
**** Entering make ref axis button
('Filepath = ', '/usr/share/gmoccapy/images/ref_all.png')
('Filepath = ', '/usr/share/gmoccapy/images/ref_0.png')
('Filepath = ', '/usr/share/gmoccapy/images/ref_1.png')
('Filepath = ', '/usr/share/gmoccapy/images/ref_2.png')
('Filepath = ', '/usr/share/gmoccapy/images/ref_3.png')
('Filepath = ', '/usr/share/gmoccapy/images/ref_4.png')
('Filepath = ', '/usr/share/gmoccapy/images/unhome.png')
**** Entering make touch button
**** Entering make jog increments
**** Entering make jog button
**** Entering make joints button
**** arrange JOINTS button
Found 10 Joints Button
**** Entering make macro button
found 0 Macros
**** arrange DRO
4
**** Place in table
**** get DRO order
**** arrange JOG button
less than 6 axis
**** no audio available! ****
**** PYGST libray not installed? ****
**** is python-gstX.XX installed? ****
**** Entering init gremlin ****
Kinematics type changed
('_set_enable_tooltips = ', True)
**** No virtual keyboard installed, we checked for <onboard> and <matchbox-keyboard>.
**** GMOCCAPY INFO: Gcode.lang found ****
Wrong entry [DISPLAY] CYCLE_TIME in INI File!
Will use gmoccapy default 150
**** GMOCCAPY INFO : inifile = /home/pi/linuxcnc/configs/plasma/plasma.ini ****:
**** GMOCCAPY INFO : postgui halfile = postgui.tcl ****:
Jog Pin Changed
x+
Jog Button released = x+
Jog Pin Changed
x-
Jog Button released = x-
Jog Pin Changed
y+
Jog Button released = y+
Jog Pin Changed
y-
Jog Button released = y-
Jog Pin Changed
z+
Jog Button released = z+
Jog Pin Changed
z-
Jog Button released = z-
Jog Pin Changed
a+
Jog Button released = a+
Jog Pin Changed
a-
Jog Button released = a-
Jog Pin Changed
0+
Jog Button released = 0+
Jog Pin Changed
0+
Jog Pin Changed
1+
Jog Button released = 1+
Jog Pin Changed
1+
Jog Pin Changed
2+
Jog Button released = 2+
Jog Pin Changed
2+
Jog Pin Changed
3+
Jog Button released = 3+
Jog Pin Changed
3+
Jog Pin Changed
4+
Jog Button released = 4+
Jog Pin Changed
4+
IDLE
1 2
MANUAL Mode
RUN
IDLE
ntb_button_switch_page
('on button home clicked = ', 'ref_all')
('Hal Status not all homed', '0124')
('Hal Status not all homed', '124')
('Hal Status not all homed', '12')
('Hal Status not all homed', '2')
Combi DRO all homed
Combi DRO all homed
Combi DRO all homed
Combi DRO all homed
hal status motion mode changed
Hal Status all homed
Jog Button pressed = y-
Jog ButtShutting down and cleaning up LinuxCNC...
task: 9501 cycles, min=0.000150, max=2.166802, avg=0.010410, 2 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:86:c3
hm2_eth: discovered 7I96S
hm2/hm2_7i96s.0: Low Level init 0.15
hm2/hm2_7i96s.0: Smart Serial Firmware Version 43
hm2/hm2_7i96s.0: 51 I/O Pins used:
hm2/hm2_7i96s.0: IO Pin 000 (TB3-01): InM Input Module #0, pin in0 (Input)
hm2/hm2_7i96s.0: IO Pin 001 (TB3-02): InM Input Module #0, pin in1 (Input)
hm2/hm2_7i96s.0: IO Pin 002 (TB3-03): InM Input Module #0, pin in2 (Input)
hm2/hm2_7i96s.0: IO Pin 003 (TB3-04): InM Input Module #0, pin in3 (Input)
hm2/hm2_7i96s.0: IO Pin 004 (TB3-05): InM Input Module #0, pin in4 (Input)
hm2/hm2_7i96s.0: IO Pin 005 (TB3-06): InM Input Module #0, pin in5 (Input)
hm2/hm2_7i96s.0: IO Pin 006 (TB3-07): InM Input Module #0, pin in6 (Input)
hm2/hm2_7i96s.0: IO Pin 007 (TB3-08): InM Input Module #0, pin in7 (Input)
hm2/hm2_7i96s.0: IO Pin 008 (TB3-09): InM Input Module #0, pin in8 (Input)
hm2/hm2_7i96s.0: IO Pin 009 (TB3-10): InM Input Module #0, pin in9 (Input)
hm2/hm2_7i96s.0: IO Pin 010 (TB3-11): InM Input Module #0, pin in10 (Input)
hm2/hm2_7i96s.0: IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96s.0: IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96s.0: IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96s.0: IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96s.0: IO Pin 015 (TB3-21/TB3-22): OutM Output Module #0, pin Out-04 (Output)
hm2/hm2_7i96s.0: IO Pin 016 (TB3-23/TB3-24): OutM Output Module #0, pin Out-05 (Output)
hm2/hm2_7i96s.0: IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 025 (TB2-02/TB2-03): StepGen #4, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 026 (TB2-04/TB2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96s.0: IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96s.0: IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96s.0: IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96s.0: IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96s.0: IO Pin 032 (internal): IOPort
hm2/hm2_7i96s.0: IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96s.0: IO Pin 034 (P1-01): IOPort
hm2/hm2_7i96s.0: IO Pin 035 (P1-02): IOPort
hm2/hm2_7i96s.0: IO Pin 036 (P1-03): IOPort
hm2/hm2_7i96s.0: IO Pin 037 (P1-04): IOPort
hm2/hm2_7i96s.0: IO Pin 038 (P1-05): IOPort
hm2/hm2_7i96s.0: IO Pin 039 (P1-06): IOPort
hm2/hm2_7i96s.0: IO Pin 040 (P1-07): IOPort
hm2/hm2_7i96s.0: IO Pin 041 (P1-08): IOPort
hm2/hm2_7i96s.0: IO Pin 042 (P1-09): IOPort
hm2/hm2_7i96s.0: IO Pin 043 (P1-11): IOPort
hm2/hm2_7i96s.0: IO Pin 044 (P1-13): IOPort
hm2/hm2_7i96s.0: IO Pin 045 (P1-15): IOPort
hm2/hm2_7i96s.0: IO Pin 046 (P1-17): IOPort
hm2/hm2_7i96s.0: IO Pin 047 (P1-19): IOPort
hm2/hm2_7i96s.0: IO Pin 048 (P1-21): IOPort
hm2/hm2_7i96s.0: IO Pin 049 (P1-23): IOPort
hm2/hm2_7i96s.0: IO Pin 050 (P1-25): IOPort
hm2/hm2_7i96s.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
/usr/bin/gmoccapy:312: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
(gmoccapy:1107): GtkSourceView-CRITICAL **: 19:40:04.973: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
/usr/lib/python2.7/dist-packages/gmoccapy/notification.py:168: GtkWarning: Invalid icon size 48
self.popup.show()
/usr/bin/gmoccapy:5248: GtkWarning: Invalid icon size 48
gtk.main()
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
python2: ../../src/xcb_io.c:263: poll_for_event: Assertion `!xcb_xlib_threads_sequence_lost' failed.
/usr/bin/linuxcnc: line 896: 1107 Aborted $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
1054
1103
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Mon 11 Nov 2024 07:44:27 PM EET
UTC Date: Mon 11 Nov 2024 05:44:27 PM UTC
this program: /usr/bin/linuxcnc_info
uptime: 19:44:27 up 5 min, 2 users, load average: 1.00, 1.22, 0.64
lsb_release -sa: Raspbian Raspbian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/pi/linuxcnc/configs/plasma
USER: pi
LOGNAME: pi
HOME: /home/pi
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: LXDE-pi
display size: 1200x1280 pixels (318x339 millimeters)
PATH: /usr/bin:/home/pi/linuxcnc/configs/plasma/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: raspberrypi
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Fri Jan 1 21:15:16 GMT 2021
machine -m: armv7l
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=1200 bcm2708_fb.fbheight=1280 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:F7:46:81 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=fdc20b50-02 rootfstype=ext4 elevator=deadline fsck.repair=yes isolcpus=3 idle=poll rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=LT
model name: ARMv7 Processor rev 3 (v7l)
cores:
cpu MHz:
parport:
serial:
Versions:
gcc: gcc (Raspbian 8.3.0-6+rpi1) 8.3.0
python: Python 2.7.16
git: git version 2.20.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.4 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
ii linuxcnc-uspace 1:2.8.4 armhf motion controller for CNC machines and robots
Thank you
Report:
Warning: Spoiler!
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.4
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYYZA
33554435
41943043
37748739
35651587
39845891
31457283
44040195
(1, ' = ', '-ini')
Entry = trivkins
joint 0 = axis x
joint 1 = axis y0
joint 2 = axis y1
joint 3 = axis z
joint 4 = axis a
axis_list =
found 0 Macros
**** arrange DRO
4
**** Place in table
**** get DRO order
less than 6 axis
Jog Pin Changed
x+
Jog Pin Changed
x-
Jog Pin Changed
y+
Jog Pin Changed
y-
Jog Pin Changed
z+
Jog Pin Changed
z-
Jog Pin Changed
a+
Jog Pin Changed
a-
Jog Pin Changed
0+
Jog Pin Changed
0+
Jog Pin Changed
1+
Jog Pin Changed
1+
Jog Pin Changed
2+
Jog Pin Changed
2+
Jog Pin Changed
3+
Jog Pin Changed
3+
Jog Pin Changed
4+
Jog Pin Changed
4+
IDLE
1 2
MANUAL Mode
RUN
IDLE
Combi DRO all homed
Combi DRO all homed
Combi DRO all homed
Combi DRO all homed
hm2: unloading
self.popup.show()
gtk.main()
1054
1103
pastebin.com
USER: pi
LOGNAME: pi
HOME: /home/pi
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: LXDE-pi
uname items:
machine -m: armv7l
/proc items:
cores:
cpu MHz:
parport:
serial:
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
Thank you
Last edit: 11 Nov 2024 18:24 by domse.
- Thank you received: 5330
11 Nov 2024 19:25 #314277
Replied by PCW on topic Linuxcnc crashing randomly when pressing buttons
Not any real help but
looks like the cause of the crash, possibly a GUI bug
Time to create page: 0.072 seconds
