10 or 11 stepgen
- rajsekhar
- Thank you received: 12
17 Nov 2024 16:51 #314676
by rajsekhar
10 or 11 stepgen was created by rajsekhar
How can I use 10 or 11 stepgen with mesa? What cards to be used?
- Thank you received: 5330
17 Nov 2024 17:08 - 17 Nov 2024 17:58 #314678
Replied by PCW on topic 10 or 11 stepgen
A 7I96S + 7I88 would give you 12 or 13 stepgen outputs (depending
on whether you use the 7I88 as 7 stepgens+ RS-485 or 8 stepgens)
A 7I96S+ a common Mach 5 axis BOB (5ABOB) would give you 10
Last edit: 17 Nov 2024 17:58 by PCW.
- rajsekhar
18 Nov 2024 03:18 #314712
by rajsekhar
Replied by rajsekhar on topic 10 or 11 stepgen
Well, I have attached the brochure for 5 axis BOB.
I have used such board earlier.
Now, can I use it through a parallel port of the computer for stepgen while having Mesa 7i92+daughter cards ?
- Thank you received: 7488
18 Nov 2024 11:13 #314741
Replied by tommylight on topic 10 or 11 stepgen
Yes.
18 Nov 2024 16:21 #314767
You can run that card from a 7I92,7I92T,7I96,7I96S etc also
Time to create page: 0.107 seconds
