xbox controler for cnc
22 Nov 2024 22:02 #315060 by jonsar
xbox controler for cnc was created by jonsar
Hi All
i would like some help / direction  in setting up a wired xbox controler to my cnc i am using Ubuntu  10.04 the lucid lynx  ,linux cnc 2.5.3
any poiinters thanks
24 Nov 2024 23:05 #315198 by tommylight
Replied by tommylight on topic xbox controler for cnc
10.04 is 14 years old by now, but if it works for you, do not change it.
As for X-Box controller, it will probably not be recognized by such old kernel, but you might be able to find something if you search for "xbox ubuntu 10" and use that to implement into LinuxCNC (or EMC2 as you have it).
Another thing you might want to do is, download the Wheezy ISO from the downloads page, write to USB, boot from that USB, plug the controller, open a text editor with some text, see if you can move the cursor.
If that does not work, download the 2.9.3 ISO, write, boot, try some text.
All this is untested, but i might give it a try if i go to the shop tomorrow, i think i have an xbox controller somewhere.
The following user(s) said Thank You: jonsar
