PROBLEM SETING UP LINUX CNC -111
23 Nov 2024 15:05 #315108 by benjamin
PROBLEM SETING UP LINUX CNC -111 was created by benjamin
Hello !
I have a problem with setting up linux cnc i go thru pconf and when i want to run my configuration a get the next error message.
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Connection refused (-111)
./deckel.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./deckel.hal:9: /usr/bin/rtapi_app exited without becoming ready
./deckel.hal:9: insmod for hm2_eth failed, returned -1
2097
Stopping realtime threads
Unloading hal components
23 Nov 2024 15:10 #315111 by PCW
Replied by PCW on topic PROBLEM SETING UP LINUX CNC -111
Sounds like possibly an IP address issue
What IP address did you select in pncconf and what IP address is set on the host?
ip a
will report the host IP address's
23 Nov 2024 15:15 #315112 by benjamin
Replied by benjamin on topic PROBLEM SETING UP LINUX CNC -111
I was just able to fix the problem i wrote the wrong ip adress 10.10.10.11 .
Thanks for the reply anyway !
Time to create page: 0.306 seconds
