LinuxCNC 32 BITS
24 Nov 2024 23:25 #315203 by Toribio1898
LinuxCNC 32 BITS was created by Toribio1898
Hola a tod@s!. Buscaba mis consultas de meses atrñas, para no molestar, pero seguramente se debe haber borrado, por espacios o políticas contructivas de la página.
Simplemente necesito descargar LinuxCNC 32 bits, para instalarlo y probarlo, también agradecería si hay proyectos realizados con dicha distro.
Desde ya Muchísimas Gracias!.
25 Nov 2024 01:04 #315207 by royka
Replied by royka on topic LinuxCNC 32 BITS
用英語問你的問題會有幫助
The following user(s) said Thank You: Toribio1898
25 Nov 2024 01:32 #315208 by tommylight
06 Dec 2024 12:51 #316093 by Toribio1898
Replied by Toribio1898 on topic LinuxCNC 32 BITS
Hello!. Thank you very much! I have a 32-bit HP Mini with 2 gigabytes of ram and an SSD. Searching on Google, I found my old consultation with you, where you gave me LinuxCNC 32 bits and Ubuntu, just like the one you just gave me.
Could it be the nvidia card that my HP mini has? The 32-bit LinuxCnc, its start screen is stuck, I don't see any progress, to be able to install that version, on the other hand, Ubuntu starts up just fine and I think I could install it without problems, but I want to manage a machine with LinuxCnc 32 bits, I consider that Ubuntu is only for simulation. I hope you can offer me a solution. Thanks a lot!...
I used a translator, so that you can read more calmly, thanks for the suggestion to the person who wrote to me in another language outside of English, for my Chinese. Thank you, thank you!
06 Dec 2024 14:14 #316103 by tommylight
Replied by tommylight on topic LinuxCNC 32 BITS
Ubuntu 10.04 with LinuxCNC
linuxcnc.org/iso/ubuntu-10.04-linuxcnc3-i386.iso
Does the HP have a parallel port?
09 Dec 2024 00:47 #316295 by JT
Replied by JT on topic LinuxCNC 32 BITS
I'm running Ubuntu 10.04 on my Hardinge CHNC lathe with no problems on an old PC. Been running it for years and don't need to upgrade what is not broken.
JT
26 Dec 2024 00:43 #317379 by Toribio1898
Hello, thank you very much and a very Merry Christmas!...
It doesn't have that port, what board do you recommend for this little one?
Thanks a lot!...
26 Dec 2024 00:48 #317380 by Toribio1898
Since I would like to see your project, maybe share it on your YouTube channel, I want to learn and I was really happy with the news that I could use Ubuntu to work seriously.
Thanks a lot!...
26 Dec 2024 07:49 #317392 by tommylight
25 Jan 2025 03:09 #319801 by Toribio1898
Hello. Thank you very much for what you share with me. I have already subscribed to you, but unfortunately, you do not offer me the option to translate the audio from your videos into my Spanish. There is some tool in Linux to achieve this translation.
I will install the Ubuntu that they shared with me, but how much ram do they use to work with?
What USB board do you recommend for my 32-bit netbook? Very kind and excuse my ignorance...
Time to create page: 0.168 seconds
