Following error new installation Pi5 stepper motor mill
- Ian@eagland.co.uk
26 Nov 2024 15:41 #315307
by Ian@eagland.co.uk
Following error new installation Pi5 stepper motor mill was created by Ian@eagland.co.uk
Hi
Background. Taig 3 axis mill with stepper motors. Been running for about 10 years. Was PC based but PC failed.
I had Pi5 to hand so bought HAT from byte2bot and a breakout board.
I used the HAL file and ini file from byte2bot modifying with information from the old PC ini file and setting pin allocations to match Pi.
just starting setup sorting out home and limit switches. X axis works perfectly but when I try Y axis I am getting a following error fault.
I understand the basics of following error on a servo machine. How can you get a following error on a stepper drive and what do I need to do to solve the issue? FERROR set to 1.
Are there any other sample Pi5 HAL files available to download?
Regards
Ian
Regards
Ian
- Thank you received: 2176
28 Nov 2024 10:01 #315449
Replied by Aciera on topic Following error new installation Pi5 stepper motor mill
Please post your hal and ini files.
28 Nov 2024 10:08 #315452
If that is a 'real' email address you are using as your username you may want to change your username to something else. It's quite likely to get sucked up by some web bot looking for such things.
Time to create page: 0.073 seconds
