f-engrave error
- neil52
27 Nov 2024 22:56 - 27 Nov 2024 23:50 #315423
by neil52
f-engrave error was created by neil52
PIL not loaded.
File "f-engrave.py", line 348, in <module>
import pyclipper
ImportError: No module named pyclipper ;Ive installed pyclipper still get this message
import pyclipper
Last edit: 27 Nov 2024 23:50 by neil52.
- Thank you received: 7488
27 Nov 2024 23:33 #315425
Replied by tommylight on topic f-engrave error
No double posting.
F-engrave has nothing to do with LinuxCNC, so you should have used google for that, it would come back as missing dependencies and probably with the solution as what to install.
Another thing you should check is if the f-engarave has been ported to Python 3, it was Python 2 only.
- neil52
27 Nov 2024 23:54 #315427
by neil52
Replied by neil52 on topic f-engrave error
sorry for double post not intentional. I did google and tried their solutions to no avail.thought I would try here.guess I will try the developer.
28 Nov 2024 00:42 #315429
Is f-engrave from ScorchWorks?
If yes, try editing the file and where it says python at the top change to python2, save try running, then try python3.
The following user(s) said Thank You: neil52
