- LinuxCNC
- General LinuxCNC Questions
- Simple one.... how to eleminate "Do you really want to close LinuxCNC?"
- slowpoke
- Thank you received: 28
28 Nov 2024 20:11 #315488
by slowpoke
Simple one.... how to eleminate "Do you really want to close LinuxCNC?" was created by slowpoke
Thanks , but nanny not required, how do I get axis to just close and not ask?
...and while I'm at it what about eliminating the 30 second delay for computer shut-down, can it just do it when I ask?
Thanks....
Thanks....
- cakeslob
- Thank you received: 280
29 Nov 2024 04:54 #315512
by cakeslob
Replied by cakeslob on topic Simple one.... how to eleminate "Do you really want to close LinuxCNC?"
The following user(s) said Thank You: Aciera, slowpoke
- slowpoke
29 Nov 2024 14:38 #315550
by slowpoke
To use this, do I simply add the root_window..... to a particular file, or do I need to tweak the source code and then compile?
I'm up for the former, no clue if I need to re-compile.14.2. Disable the Close Dialog# disable the do you want to close dialog
root_window.tk.call("wm","protocol",".","WM_DELETE_WINDOW","destroy .")
Replied by slowpoke on topic Simple one.... how to eleminate "Do you really want to close LinuxCNC?"
I'm not a software guy....In axis?
linuxcnc.org/docs/stable/html/gui/axis.h...ble_the_close_dialog
- cakeslob
29 Nov 2024 14:47 #315552
by cakeslob
put that stuff into a python file and add it to your ini, or in the axisrc file for it to work globally. no need to compile
linuxcnc.org/docs/stable/html/gui/axis.html#sub:axis-axisrc
- Thank you received: 4150
29 Nov 2024 18:47 #315569
Replied by rodw on topic Simple one.... how to eleminate "Do you really want to close LinuxCNC?"
to save 30 seconds out of your life try
sudo shutdown now
You might need to give permissions to skip the sudo password
askubuntu.com/questions/147241/execute-sudo-without-password
sudo shutdown now
- slowpoke
29 Nov 2024 22:29 #315592
by slowpoke
where is .axisrc? or do I need to create it? and does it need a file name before the extension?
What does "mean?
I'm guessing here.... there might be a file ending with
~/.axisrc ???where is .axisrc? or do I need to create it? and does it need a file name before the extension?
What does "
~/"I'm guessing here.... there might be a file ending with
".axisrc" possibly in the folder associated with the particular GUI I'm using, but I don't see one, so perhaps I need to create one?
I'm a little lost here guys?Please Log in or Create an account to join the conversation.
29 Nov 2024 23:18 #315594
A file starting with a period denotes a hidden file.
You can tell thunar browser to show them.
The tilde ~ is shorthand for your home folder,
The following user(s) said Thank You: slowpoke
- slowpoke
30 Nov 2024 08:33 #315619
by slowpoke
- LinuxCNC
Time to create page: 0.152 seconds
