7i77D availability
02 Dec 2024 07:28 #315788 by 3CHman
7i77D availability was created by 3CHman
Hi - The 7i77D has been out of stock for a spell - anybody know if they are going to continue this version. Im tempted to use a 7i77 with relays but if the D sinking outputs is going to become available Ill hang on.
Thanks all for a great service on this forum. Good bedtime reading
  • Moderator
  • Moderator
02 Dec 2024 08:37 #315794 by tommylight
Replied by tommylight on topic 7i77D availability
Germany
www.welectron.com/Motion-Controller_1
no 7i77 at all
Portugal
eusurplus.com/index.php?route=product/pr..._61_60&product_id=51
Has in stock normal 7i77 without the D.
USA
mesaus.com/product/7i77/
has 2 of 7i77 without D in stock
store.mesanet.com/index.php?route=produc...69_71&product_id=120
20 of 7i77 in stock, again no D
02 Dec 2024 09:17 #315797 by PCW
Replied by PCW on topic 7i77D availability
How many outputs do you need?
A 7I97T may work (and if more outputs were needed a 7I84U could be added)
Should have a 7I77U (Universal outputs) available but about middle next year
02 Dec 2024 15:25 #315835 by 3CHman
Replied by 3CHman on topic 7i77D availability
Thanks for the info guys. They are no longer building the 7i77D as you have all sussed out - so Ill use the 7i77 with a bit of extra logic. I need the X6 servo interface the 7i77 gives and Ive got the current 7i77D built in so Ill pursue that path for the mo . Ill check out the 'U' options though for the future
Thanks again..
20 Jan 2026 16:39 - 20 Jan 2026 16:44 #341627 by PCW
The 7I77 and 7I77D have both been replaced by the 7I77U
The 7I77U has Universal outputs (sinking, sourcing, or push-pull,
settable on a per output basis)
There is 1 (!) left in stock at Mesa from the proto run with production to follow soon.
Last edit: 20 Jan 2026 16:44 by PCW.
Time to create page: 0.489 seconds
