round holes not exactly round.
05 Dec 2024 21:12 #316047 by COFHAL
round holes not exactly round. was created by COFHAL
I have a problem when making round cavities or holes. In the axes corresponding to the angles 0 -180 and 90 -270 the dimensions are correct, but in the diagonals the dimensions are no longer correct, in the diagonal 45-225 the dimension is smaller and in the diagonal 135-315 the dimension is larger.
05 Dec 2024 22:01 #316053 by hmnijp
Replied by hmnijp on topic round holes not exactly round.
Your problem is caused by screw backlash
06 Dec 2024 00:17 #316063 by tommylight
Replied by tommylight on topic round holes not exactly round.
First make sure the scaling is correct for all axis, then check for backlash or loose screws or mounts.
Also check for mount deflection while machine is working.
06 Dec 2024 03:35 #316070 by timo
Replied by timo on topic round holes not exactly round.
How much "problem" is there? What type of machine? Even in CNC boring heads with a single point cutter are still "a thing".
Maybe your axis are not exactly perpendicular?
Can you measure it simehow?
I had huge backlash on my 2nd hand machine, the rubbers of the couplers between ball screw and coupler were "disappeared".
Another thing I found is a damaged bearing that keeps the ball screw in place. Then the complete screw can move a little.
Happy trouble shooting
27 Dec 2024 14:49 #317477 by User_paulvdh_42
Replied by User_paulvdh_42 on topic round holes not exactly round.
If one diagonal is too short, and the other too long, then it's likely the axis of your machine are not perpendicular to each other.
Time to create page: 0.226 seconds
