Z and Corner Finding Touch Plate
- HogWild
06 Dec 2024 19:47 #316130
by HogWild
Z and Corner Finding Touch Plate was created by HogWild
Is there a Z and corner finding touch plate you recommend that Linux already supports? In other words, is there programming support already developed for particular touch plates? If so, it seems it would be much easier to use one that has programming already developed.
Interested to see what you recommend.
- Thank you received: 4149
07 Dec 2024 02:13 #316145
Replied by rodw on topic Z and Corner Finding Touch Plate
Its called a 3D probe. Assumes you have repeatable tooling. Works a treat with QT-Dragon.
The following user(s) said Thank You: HogWild
