Feedback control XY not full speed run G1 when curve or Arc
07 Dec 2024 06:38 #316160 by abdulasis12
Hi
I use servo motor 750W  and encoder from motor connect to 7i77  X and Y axis Feedback control
I use fusion360 for CAM and option G64 P0.002 Q0.002
when my cnc run process  Adaptive clearing toolpath is curve or  Arc  I few cnc base little jerky and feed in Gcode(G1) is 1200 mm/mins but CNC just run 100-300 mm/mins
How to fix this problem ?
I don't know where setting wrong.
Thank you
Asis
07 Dec 2024 08:31 #316166 by Aciera
Can you post your gcode or at least a section of it?
The following user(s) said Thank You: abdulasis12
07 Dec 2024 13:49 #316189 by tommylight
Also, what acceleration is set in the ini file?
08 Dec 2024 17:34 #316261 by abdulasis12
Hi, MR.ACIERA  MR. TOMMY
Thank you for reply and sorry in weekend slow reply.
This below post file gcode problem.
example about in gcode file at N15 to N3900
**Also, what acceleration is set in the ini file?**
Tomorow at workshop I will check and told again.
Thank you
Asis,
File Name: 1001.ngc
File Size:648 KB
09 Dec 2024 08:55 #316314 by abdulasis12
Hi Tommy
This is my ini file .
File Name: 217-4x_2024-12-09.ini
File Size:9 KB
09 Dec 2024 12:33 #316324 by tommylight
Traj section in the ini file, velocities are much lower than in the display section, try setting those same as display section.
09 Dec 2024 17:46 #316350 by hmnijp
You should increase motion blending tolerance (g64 p0.002)
The more accurate the tolerance -> the lower the speed.
For roughing operation (adaptive) such accuracy is not required. Try setting P0.05, this will smooth the trajectory and allow it to be executed at high speed.
If the acceleration of your machine is not high, then for roughing operation you can choose P even more.
13 Dec 2024 01:27 #316558 by abdulasis12
Hi MR.Tommy
"much lower than in the display section" Okay, I got it wrong. I think it's for the motor velocity. I will change it back to default.
Thank you,
Asis
13 Dec 2024 01:35 #316559 by abdulasis12
Hi MR.hmnijp
Thank you for the suggestion. I have applied your advice and made some adjustments. Previously, it was G64 P0.002 Q0.002. Now, I’ve changed it to G64 P0.01 and removed the Q0.002 parameter. The machine runs much more smoothly, although there are still some slight jerks when transitioning into curves during G0 moves. However, it’s a significant improvement.
Do you happen to know what the Q parameter is used for?
Thank you,
Asis
13 Dec 2024 06:39 #316563 by Aciera
The following user(s) said Thank You: Lcvette, abdulasis12
Time to create page: 0.349 seconds
