Equivalent of some Fanuc codes
13 Dec 2024 13:33 #316575 by akg1904
Equivalent of some Fanuc codes was created by akg1904
Hi Guys,
i recently got one fanuc code and it has some Gcode for which I need help to find equivalent of these line in Fanuc for LinuxCNC.
Please help me out with these codes:
1.  G5.1 Q1 R10
2.  G5.1 Q3 X0 Y0 Z0
3.  G5.1 Q0
Regards
Abhishek
14 Dec 2024 09:24 #316635 by gitin
Replied by gitin on topic Equivalent of some Fanuc codes
G05
High-speed and high-precision control Ⅰ
G05 P10000 High-speed and high-precision control opening
G05 P0 High-speed and high-precision control off
G05 P3 High-speed machining on
G05 P0 High-speed machining is off
G05.1
High speed and high precision control Ⅱ
G05.1 Q1 High-speed and high-precision control on
G05.1 Q0 High-speed and high-precision control off
G05.2 Q2 X0 Y0 Z0 Free-form surface high precision mode is on
G05.1 Q0 Free-form surface high precision mode is off
G05.1 Q1 R1 - coarse high-speed processing,
the feed at the corners does not change,
the corners are cut off, the contour does not correspond to the set one.
G05.1 Q1 R5 - high-speed processing, speed-quality balance,
deceleration at the corners, corners can still be cut.
G05.1 Q1 R10 - precise high-speed processing, significant deceleration
at the corners, the corners are not cut off, the contour corresponds
to the one set within the accuracy of the machine.
G64 P 0.01 may help. I think the professionals will correct me.
The following user(s) said Thank You: akg1904
Time to create page: 0.083 seconds
