Home position using ethercat servo position (absolute encoder value).
16 Dec 2024 02:27 #316725 by vanquang
Hi everyone.
Ưhile working with linuxcnc ethercat, I have some questions, hope to receive advice or comments from everyone.
1. Normally, we often use limit switches to determine "home position".
2. My idea is to use the servo motor position in "absolute mode" as "home position". That means, for example, in the xyz robot, I mark a fixed point on each axis, then move the axes to that point (this point will be the "home position"). Next, I read the absolute encoder values ​​from the ethercat servo command on the 3 axes, and get the value of "home position". So how can I implement the above idea?
Thank you very much.
16 Dec 2024 13:54 #316757 by onceloved
There is a setting in the driver to set the current position as the origin. It can be operated through the panel. I don't know what brand of driver you are using.
17 Dec 2024 06:56 #316839 by vanquang
Dear onceloved
Thank you for your reply.
I am using Panasonic A6 servo motor.
I have two questions in your advices.
1. When I power off the motor, and shutdown the controller. Are these values ​​saved into the controller? And When I power on the motor and Boot the controller, does this position change?
2. How can I modify in the hal file
17 Dec 2024 07:55 #316841 by onceloved
1 The absolute value will record the current coordinate position
2 Add 6098 related object dictionaries in the xml file 35 The current position is the origin
17 Dec 2024 08:46 #316844 by onceloved
I just tested 6098 on my servo drive and it cannot set the current position as the origin
18 Dec 2024 07:46 #316911 by vanquang
Dear onceloved
Normally, for cobots, origin position or zero position, they are saved some file in robot controller (txt file, or xml file). don't slave in object dictionaries of ethercat.
