How to build linuxcnc on buildroot?
20 Dec 2024 09:03 #317034 by Cong
I need to build linuxcnc in buildroot, is there any reference document?
20 Dec 2024 18:40 #317054 by tommylight
Replied by tommylight on topic How to build linuxcnc on buildroot?
What is "buildroot" ?
If you mean building from sources (on github) :
linuxcnc.org/docs/html/code/building-linuxcnc.html
If you mean buildbot:
buildbot.linuxcnc.org/
21 Dec 2024 03:03 #317072 by Cong
Replied by Cong on topic How to build linuxcnc on buildroot?
I need to port Linuxcnc to an arm system, and then I need Buildroot to build and compile linuxcnc
21 Dec 2024 03:04 #317073 by Cong
My development board uses an RK3588 motherboard
21 Dec 2024 03:22 #317074 by tommylight
There are ready made debs for ARMHF architecture here
buildbot.linuxcnc.org/dists/buster/maste...reempt/binary-armhf/
What architecture is RK3588 listed as?
21 Dec 2024 04:03 #317075 by Cong
The RK3588 is based on the ARMv8.2-A architecture and uses a 64-bit ARM (AArch64) core.
23 Dec 2024 20:05 #317222 by rodw
Replied by rodw on topic How to build linuxcnc on buildroot?
Building Linuxcnc on any hardware platforen is not difficult. I did a video of how to do it.
TheĀ  hard bit is to buildĀ  the PREEMPT_RT real time kernel as generally, there are no pre-built Debs for it. Using the 6.1.12 kernel and above will avoid the need to apply the RT patch to kernel source. This might help.
  • Platinum Member
  • Platinum Member
23 Dec 2024 23:18 #317243 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic How to build linuxcnc on buildroot?
There's no information that I can recall for cross compiling Linuxcnc.
When compiling Linuxcnc for the RPi platform (4/400 or 5) I've either done it natively or via QEMU.
For those that are unaware Buildroot is a cross compiling system for building Linux file systems, generally aimed at embedded systems.
Time to create page: 0.097 seconds
