Minimal setup for touch probe and tool setter ?
22 Dec 2024 17:03 #317149 by karnalta
Hi all,
I have an 3 axis CNC than I used rarely which is at the moment using LinuxCNC with QtDragon, but honestly, each time I try to use it, I spend the day having errors, crashes, ... It was working a few month ago and now each time the machine is about to start working (after all probing), it stop with a error like "Parameter is [3.000]".
I would like to know what is the minimal requirement to use a 3D touch probe and a tool height sensor with LinuxCNC ?
I will be glad to stick with the basic Axis UI and the minimal dependencies. All I need is :
- Touch X/Y zero with the probe.
- Touch the Z zero of my vise.
- Touch tool sensor at each tool change to adapt Z.
What is the easiest path for that ?
Thank you.
22 Dec 2024 18:44 #317153 by cakeslob
Im using the easyprobe pyvcp thing. its pretty easy for probe xyz, etc
but there is no toolsetter macro
23 Dec 2024 11:53 #317188 by karnalta
I am currently giving a try to Basic Probe.
It has both probing functions.
23 Dec 2024 23:27 #317244 by rodw
to get the most out of qtdragon's tool handling, you need repeatable tooling and premeasured tools.
With Tormach TTS tooling, they sell a small granite plate
tormach.com/small-granite-surface-plate-...tool-hole-31713.html
And you use a height gauge to measure the height of your probe and your tools
en.wikipedia.org/wiki/Height_gauge
TTS can be used in R8 and MT3 spindles found on small machines, many people use at home.
This does work a treat when you have it all set up.
24 Dec 2024 11:57 #317275 by wusel0464
Replied by wusel0464 on topic Minimal setup for touch probe and tool setter ?
Hello,
I use this method.
With a flying probe that is in a fixed position to measure the tool and for Z I place it on the workpiece, for this the correct probe height (switching point) must be entered in QTDragon.
forum.linuxcnc.org/qtvcp/39423-qtdragon-...tool-change?start=30
Frank wishes everyone best wishes, good health and a lovely relaxing holiday.
