Easy way to compensate skew in X/Y axis ?
28 Dec 2024 16:26 #317552 by karnalta
Hello all,
By the past I have used millkins to compensate 0.001mm / mm of XY squareness.
Now that I have done a fresh LinuxCNC install, I can't seem to find millkins again, probably way out dated ?
What's the actual way of adding a small skew correction to my axis ?
Is Matrixkins an up-to-date component with LinuxCNC 2.9.3 ? Is it directly embedded in the default installation ?
Thank for your help.
28 Dec 2024 17:21 #317553 by Aciera
28 Dec 2024 18:01 - 28 Dec 2024 18:12 #317554 by karnalta
Replied by karnalta on topic Easy way to compensate skew in X/Y axis ?
Have a look at this:
forum.linuxcnc.org/49-basic-configuratio...s-xyz?start=0#280714
I should have specified that I am using Basic Probe UI, look like the link you provided me only support Axis ?
EDIT I just tried and it seem to work fine with Basic Probe UI, look like it's working fine. Any warning ? I should be concerned by something ?
Thank you.
Last edit: 28 Dec 2024 18:12 by karnalta.
28 Dec 2024 19:09 #317562 by Aciera
Replied by Aciera on topic Easy way to compensate skew in X/Y axis ?
the type of gui should not interfere with the kinematics.
29 Dec 2024 10:26 #317599 by onceloved
Replied by onceloved on topic Easy way to compensate skew in X/Y axis ?
I have used Matrixkins and it is very useful, but you need to compile the comp file yourself
29 Dec 2024 13:36 #317603 by karnalta
Thank you for the info.
I am trying a piece ATM with skewkins (linked above), it look to work fine too.
Less skewing options than matrixkins (I think) but I only needed X/Y skew.
