Increase A axis speed, but maintain proper scale?
29 Dec 2024 16:47 #317621 by nick.smith
Hello,
I have an Amazon 4th axis that features a 6:1 reduction drive.
I found the thread here where you adjust the SCALE so that a G0 A360 will turn the axis a proper 360°.
However, the drive spins too slowly.
I can double the SCALE, which gives me the speed I want, but then I have to do something like G0 A180 for a full turn.
Is there a way I can speed the drive up, while maintaining proper scale?
29 Dec 2024 16:57 #317624 by tommylight
Replied by tommylight on topic Increase A axis speed, but maintain proper scale?
Joint/axis velocity in the ini file
max_velocity
That will be once on versions prior to 2.8 and twice in joint and axis for versions above 2.8.
Might also need to change the max_angular_velocity in the display section of the ini file.
29 Dec 2024 17:06 #317626 by nick.smith
Replied by nick.smith on topic Increase A axis speed, but maintain proper scale?
Thx much, this is actually PP, does that change anything?
29 Dec 2024 17:52 #317632 by tommylight
What is PP?
Parallel port?
Path Pilot?
Polypropylene?
29 Dec 2024 18:34 #317634 by nick.smith
precious penguins
but actually pathpilot.
I have changed all the max_velocity values in tormach_mill_base.ini with no change in actual 4th axis speed.
I do get speed changes if I change max_velocity in 4th_axis.inc, but it will e-stop and give me a "joint 3" error.
Please advise.
29 Dec 2024 19:11 #317635 by PCW
if you increase the joint velocity, you also need to increase the stepgen max velocity
(typically to 25% greater than the corresponding joint velocity).
If you don't do this, the actual position will lag the commanded position and you
will get a joint following error.
29 Dec 2024 19:38 #317636 by nick.smith
That looks like the ticket. Thank you very much.
07 Feb 2025 15:56 - 11 Feb 2025 14:03 #320919 by NickB
I saw your Amazon review and tracked you down here, What is the little cheap controller that you were able to make work with the axis?
Edit: for those from the future
Response via email: www.amazon.com/gp/product/B0B1HNS9L2?ie=UTF8&psc=1
Last edit: 11 Feb 2025 14:03 by NickB.
Time to create page: 0.107 seconds
