2.9.3 INI_VARS issue
- shipmodeller
- Thank you received: 3
03 Jan 2025 22:36 #317976
by shipmodeller
2.9.3 INI_VARS issue was created by shipmodeller
Using the sims.ini file, I set up the following:
[RS274NGC]
INI_VARS = 1
[TOOLSETTER]
z_tool = -1
Z_TOOL_HOME = -0.1
X_TOOL_HOME = 0
Y_TOOL_HOME = -10.25
OK ... when I boot up the system, no errors are indicated. I "home" the system, and switch to the MDI box.
I then put in the following command:
G0 Z#<_ini[TOOLSETTER]z_tool>
It errors and says that the variable doesn't exist. Hmmm... so I tried doing ..
#<_ini[TOOLSETTER]z_tool> = -1.25
It took that without issue... I then executed
and now it works. hmmm.. What am I doing wrong? It is supposed to have a variable defined during ini time... but it isn't, at least that is what I am seeing.
It is appearing to allocate the variable AFTER ok, but not during the ini ... Please set me right.
[RS274NGC]
INI_VARS = 1
[TOOLSETTER]
z_tool = -1
Z_TOOL_HOME = -0.1
X_TOOL_HOME = 0
- shipmodeller
04 Jan 2025 17:42 - 04 Jan 2025 17:45 #318110
by shipmodeller
Replied by shipmodeller on topic 2.9.3 INI_VARS issue
1: After a lot of playing around, I think I found the flaws in my thinking. First of all, the variables in the INI file MUST be capital. So changing my file as below allowed me to use it as a READ ONLY variable.
[TOOLSETTER]
Z_TOOL = -1
Z_TOOL_HOME = -0.1
X_TOOL_HOME = 0
2: You cannot CAN NOT use the ini variables as a regular read / write variable. Is this brought out in the documentation? I must have glossed over it .. see this: Nowhere in here does it state capital or read only state. I think that needs to be added to the manual.
3: So that begs another question... is there any script that can be configured to run on initialization of LinuxCNC so we can create variables and set them to certain values? I don't remember reading anything like that in the manual. It would be nice if the ini section had an entry for that.I can't really mark this solved, because of the remarks I made here. Yes, I have a better understanding now.. IF I am correct in my assumptions. But it has led to some confusion, and days wasted troubleshooting this. ( I have been programming since 1967, long retired now. )
[/code][/code][/b][/b][/b]
[TOOLSETTER]
Z_TOOL = -1
Z_TOOL_HOME = -0.1
X_TOOL_HOME = 0
[code][b][b][b][code][b][color=#3498db]Thanks for reading this.
[/color][/b]
Last edit: 04 Jan 2025 17:45 by shipmodeller.
- shipmodeller
05 Jan 2025 23:17 #318180
by shipmodeller
So I confirmed that all declared ini variables are READ_ONLY
file: src/emc/rs274ngc/interp_namedparams.cc
param.attr = PA_GLOBAL | PA_READONLY | PA_FROM_INI;
Documentation should make that clear.
- Thank you received: 2176
06 Jan 2025 08:06 #318202
Replied by Aciera on topic 2.9.3 INI_VARS issue
Looks like this is already documented, see section 4:
linuxcnc.org/docs/stable/html/gcode/over...gcode:ini-hal-params
The following user(s) said Thank You: shipmodeller
- JT
- Thank you received: 593
06 Jan 2025 14:09 #318225
by JT
gnipsel.com/linuxcnc/flexgui/hal.html#spinbox
or you can set user numbered parameters from the GUI and use them in your NC code
gnipsel.com/linuxcnc/flexgui/parameters.html
JT
Replied by JT on topic 2.9.3 INI_VARS issue
In Flex GUI you can have spin boxes to set hal values3: So that begs another question... is there any script that can be configured to run on initialization of LinuxCNC so we can create variables and set them to certain values? I don't remember reading anything like that in the manual. It would be nice if the ini section had an entry for that.I can't really mark this solved, because of the remarks I made here. Yes, I have a better understanding now.. IF I am correct in my assumptions. But it has led to some confusion, and days wasted troubleshooting this. ( I have been programming since 1967, long retired now. )
[/code][/code][/b][/b][/b][code][b][b][b][code][b][color=#3498db]Thanks for reading this. [/color][/b]
JT
- shipmodeller
06 Jan 2025 16:41 #318239
by shipmodeller
Thanks for that answer... however... it still is unanswered in my original post I did this:
"G0 Z#<_ini[TOOLSETTER]z_tool>
and now it works. hmmm.. What am I doing wrong? It is supposed to have a variable defined during ini time... but it isn't, at least that is what I am seeing."
So, it is ok to generate a variable of the form _ini[TOOLSETTER]z_tool ? That started my path down this thread. If all _ini variables are READ ONLY, then why did it all me creating and setting the variable like I did in the first example? It should have errored out and give me some message like "ini variables cannot be dynamically declared" or something like that.
I thank you for finding the documentation on the proper usage of the ini variables..
06 Jan 2025 19:20 - 06 Jan 2025 19:28 #318251
Last edit: 06 Jan 2025 19:28 by Aciera.
- shipmodeller
06 Jan 2025 19:28 #318252
by shipmodeller
I repeated these issues with both the axis.ini setup for sim, and MY_MILL.ini. interesting. 2.9.3 LinuxCNC distribution, no mods. total install of ISO
06 Jan 2025 19:32 #318253
- shipmodeller
06 Jan 2025 19:48 #318254
by shipmodeller
Thanks... I'll try the same thing yet again, and post my results
Time to create page: 0.207 seconds
