STMBL V4.3 Setting smart serial node address
- dmalcolm
05 Jan 2025 02:24 #318145
by dmalcolm
STMBL V4.3 Setting smart serial node address was created by dmalcolm
Hi All
I have been trying to set the smart serial node addresses in stmbl config so I can use multiple stmbl modules with an 7i96s.
Could anyone enlighten me as to how to set node addresses in the stmbl?######## software info ########STMBL v0.9.18 v0.9.18-184-g9590cb33Branch masterCompiled 2024-12-28 15:41:15 by scott on scott-Ubuntu-iMacGCC 10.3.1 20210621 (release)newlib 3.3.0CMSIS 4.30StdPeriph 1.6.0size: 340888 crc:65008998######## Bootloader info ########STMBL-Bootloader v0.9.18 v0.9.18-184-g9590cb33######## HV info ########STMBL-hv-f303 v0.9.18 v0.9.18-184-g9590cb33hv start:0x801024c ,size:0x1a54c ,end0x802a798
Many thanks in advance.
Dean
Dean
- Thank you received: 2181
06 Jan 2025 04:19 #318188
Replied by cmorley on topic STMBL V4.3 Setting smart serial node address
I use two stmbl - I just plug them in, but I use a different card and a 7i44.
I think each stmbl needs a separate smart serial connection.
- dmalcolm
06 Jan 2025 06:18 #318196
by dmalcolm
Replied by dmalcolm on topic STMBL V4.3 Setting smart serial node address
Thanks cmorley for responding,
I was under the impression the sserial was capable of having multiple nodes, a bit like rs485, i am going to need to connect 6 axes.
I will keep hoping and trying.
Regards
Dean
Regards
Dean
