THCAD 10 question
- ric812
07 Jan 2025 03:13 #318278
by ric812
THCAD 10 question was created by ric812
- Thank you received: 4149
07 Jan 2025 05:29 #318280
Replied by rodw on topic THCAD 10 question
I wouldn't use the 50:1 voltage divider. a THCAD5 with a 5 volt full scale would be more suited to use with it. Instead just calibrate the THCAD to read 200 to 300 volts full scale with a resistor.
- ric812
09 Jan 2025 19:20 #318563
by ric812
Replied by ric812 on topic THCAD 10 question
Would the resistor I have listed work for the THCAD to read the voltage?
- Thank you received: 5329
09 Jan 2025 20:02 #318570
Replied by PCW on topic THCAD 10 question
One 2.4M resistor in series to the negative lead will give you a 250V full scale range
which should be OK
which should be OK
- ric812
11 Jan 2025 23:10 #318716
by ric812
Thank you for the info
Time to create page: 0.151 seconds
