G2
11 Jan 2025 19:32 #318701 by claytoncramer
G2 was created by claytoncramer
What I am trying to do: in a 1" x 1" square workpiece, cut a .68" ID hole starting at (.16",.16").  The mill is .125" nminal diameter.  It is actually .122".
The gCode I tried, producing a hole that is too small:
g1 x.16 y.16 f25
g1 z0 f25
g2 i.-34
12 Jan 2025 08:25 #318739 by Aciera
Replied by Aciera on topic G2
What have you set as your tool diameter and how much is 'too small'?
13 Jan 2025 22:49 #318895 by claytoncramer
Replied by claytoncramer on topic G2
I may have solved it. There are dozens of G2/G3 examples on YouTube and only one seems to provide useful instruction.
13 Jan 2025 23:07 #318898 by tommylight
Replied by tommylight on topic G2
What video on youtube?
It might be helpful to others ...
14 Jan 2025 02:14 #318918 by claytoncramer
was the only useful one for me. This is the bash scrip that I wrote to produce a hole centered in a box specified by four points. There are two files that this script uses.
#!/bin/bash
# Cut an interior circle starting at xStartBB yStartBB xEndBB yEndBB zStart zStep zEnd feedRate holeDiameter endMillDiameter
# BB is short for BoundingBox
if [ "$#" -eq 0 ];
then echo "$0 xBB yBB xEndBB yEndBB zStart stepZ endZ feedRate holeDiameter endMillDiameter"
else
xStartBB=$1
yStartBB=$2
xEndBB=$3
yEndBB=$4
startZ=$5
stepZ=$6
endZ=$7
feedRate=$8
holeDiameter=$9
endMillDiameter=${10}
millRadius=`echo "$endMillDiameter/2"|bc -l`
# Calculate starting cut points
echo $xEndBB $xStartBB $holeDiameter
center=`echo "(($xEndBB-$xStartBB)/2)"|bc -l`
offset=`echo "((($xEndBB-$xStartBB)-($holeDiameter))/2)"|bc -l`
startXCut=`echo "$xStartBB+$offset+$millRadius"|bc -l`
startYCut=`echo "($yEndBB-$yStartBB)/2"|bc -l`
endYCut=$startYCut
endXCut=`echo "$yEndBB - $offset - $millRadius"|bc -l`
# calculate radius for i
i=`echo "($center-$startXCut)"|bc -l`
cat prolog.nc >rotate.nc
echo "g1 z1.0 f$feedRate" >>rotate.nc
echo "g1 x$startXCut y$startYCut f$feedRate" >>rotate.nc
echo "g1 z$startZ y$startYCut f$feedRate" >>rotate.nc
newstartZ=`echo "$startZ+$stepZ"|bc -l`
for curZ in `seq $newstartZ $stepZ $endZ`
do
echo "g1 z$curZ f$feedRate" >>rotate.nc
echo "g2 x$endXCut y$endYCut i$i j0 f$feedRate" >>rotate.nc
echo "x$startXCut y$startYCut j0 i-$i" >>rotate.nc
done
cat epilog.nc >>rotate.nc
fi
The two external files are prolog.nc
g17 g20 g54
and epilog.nc
m2
Time to create page: 0.188 seconds
