get a bad character '/' on probe macro
- Deckerjwd
- Thank you received: 3
12 Jan 2025 20:14 #318822
by Deckerjwd
get a bad character '/' on probe macro was created by Deckerjwd
I installed a fusion 360 post processor, with probing macros
put the path in linuxcnc, set up the probe and tried to load the circle hole probe. i get bad char '/' near line 27
the macro loads up in linuxcnc and the probe g-code doesn't contain any /, tried a different macro and get the same error
not sure how to trouble shoot thisĀ
- Deckerjwd
13 Jan 2025 22:03 #318890
by Deckerjwd
Replied by Deckerjwd on topic get a bad character '/' on probe macro
ok so i started writing some macros, to test and they all work so the fusion ones i downloaded must be sending the char or returning something wrong
i will keep working on it
- Deckerjwd
18 Jan 2025 15:35 #319292
by Deckerjwd
got back to this looks like it in the macros, wrote a probe micro and ran it with no problems. guess i need to look at the macros themselves and see if i can find were the '/' is getting sent to the code
- Deckerjwd
18 Jan 2025 16:41 #319295
by Deckerjwd
went though all the macros and found // comment instead of a () comments
got all the / out and they work. im using tormack probe macros not sure if they work on that system
Time to create page: 0.417 seconds
