Why does MOTMOD create its own threads?
- drose
12 Jan 2025 20:33 #318823
by drose
Why does MOTMOD create its own threads? was created by drose
Hi all,
This question is coming from me trying to better understand motmod. What about motmod makes so that this comp needs to create and manage its threads instead of having the "threads" module handle setting up threads and then loading motmod after?
So far I understand that threads need to be loaded in a particular order (fastest to slowest) and that motmod also ensures that the base and servo thread are integer multiples of each other. Besides this what other things does the motion planner need to guarantee about its threads to work properly?
17 Jan 2025 18:18 #319201
Replied by andypugh on topic Why does MOTMOD create its own threads?
I have always assumed it was just a convenience thing, but have never really looked into it.
The following user(s) said Thank You: drose
- Grotius
- Thank you received: 2349
17 Jan 2025 19:16 #319211
by Grotius
Replied by Grotius on topic Why does MOTMOD create its own threads?
Motmod is a component like tpmod.
rtapi creates posix threads. Rtapi does not care about thread speeds. Each posix thread calls a list off components. Then rtapi calls a function order into the component itself with dlopen...
motmod does not create threads.
motmod is a trajectory planner coordinator and supervisor.
17 Jan 2025 19:19 #319212
motmod does create threads, in the sense that "loadrt motmod ......" will create the base and servo threads with the given rates.
- Grotius
17 Jan 2025 19:30 #319215
by Grotius
If you read it like that you think its modmot loading threads. But reality is different.
rtapi creates the threads.
- drose
20 Jan 2025 19:23 #319482
by drose
Replied by drose on topic Why does MOTMOD create its own threads?
Ok, so it would be reasonable to assume that if I moved the rtapi call from motmod/tpmod to somewhere else I should not expect weird side effects since this is all done through the fairly standard RTAPI API.
One other question I have is, why is there a limit on the # of threads created and the order they are created in? Is this again a convenience/limitation made to simplify things or more of a deliberate design trade-off?
- Grotius
20 Jan 2025 21:57 - 20 Jan 2025 22:41 #319497
by Grotius
To understand the function call flow from rtapi to components i made a compact example a while ago.
This is a universal approach, same as lcnc uses:
function loader
Normally you can just create new thread. This one uses a json file to load threads, shared mem, components.
new thread
The dlopen call from rtapi is straight into the component motmod or tpmod lib's function.
You can not move it around, but you can create logic to manipulate or change rtapi calls.
I did not know this but in terminal : ulimit -a
Is the limit of posix threads for users. Admins may do more.
function loader
new thread
Last edit: 20 Jan 2025 22:41 by Grotius.
Time to create page: 0.096 seconds
