How to call a python script in gcode
14 Jan 2025 16:25 #318957 by Ehsan_R
How to call a python script in gcode was created by Ehsan_R
I want to create a python script that generates 12 non-repeating random numbers every time the gcode file is run and then stores these numbers in variables that can be used in the rest of the gcode.
It is also necessary to save the values ​​of these variables in a file and to be able to see them in the graphical interface to avoid creating a string of duplicate numbers.
14 Jan 2025 19:29 - 14 Jan 2025 19:34 #318976 by programador
Replied by programador on topic How to call a python script in gcode
Hello, you can create a custom command it would be M100-M199 User Defined Commands link  linuxcnc.org/docs/html/gcode/m-code.html#mcode:m100-m199  Custom command
In the command file, place the python file to be executed, for example:
#! /usr/bin/python2.7 import sys print("Hello World")
This way, every time you execute the in the g-code script, it will execute the command desired python file.
Last edit: 14 Jan 2025 19:34 by programador.
14 Jan 2025 19:40 #318977 by Aciera
Replied by Aciera on topic How to call a python script in gcode
There are different ways of doing this. I would do it with a python remap.
Here is a basic example that creates an 'M456' command that generates a random number and stores it in a gcode parameter named #<_random_value>.  You would need to add the other stuff with the file.
1. save this as 'toplevel.py' to a folder named 'python' in your configuration folder:
import remap
2. save this as 'remap.py' tot the folder named 'python' created above:
from interpreter import *
def m456(self):
    import random
    random_value = random.randint(0, 10000000000)
    self.execute("#<_random_value> = %f " % random_value, 1)
    yield INTERP_EXECUTE_FINISH
3. Add this line to the [RS274NGC] section of your ini file:
REMAP = M456  modalgroup=10   python=m456
4. make sure you have  this in your ini file:
[PYTHON]
PATH_PREPEND= python
# import the following Python module
TOPLEVEL= python/toplevel.py
# the higher the more verbose tracing of the Python plugin
LOG_LEVEL = 8
5. start your config and run MDI command:
M456
6. to check the result run MDI command:
(debug, #<_random_value>)
should return something like this:
The following user(s) said Thank You: onceloved, Unlogic, Cant do this anymore bye all, Ehsan_R
18 Jan 2025 17:53 - 18 Jan 2025 18:06 #319299 by Ehsan_R
Replied by Ehsan_R on topic How to call a python script in gcode
Thank you very much for your reply
I acted in this way
By running the following program, two txt files will be created, one to save the new numbers created in a specified format and the other to save all the numbers to avoid repetition.
import random
import os
existing_filename = 'random_numbers.txt'
new_numbers_filename = 'new_random_numbers.txt'
if os.path.exists(existing_filename):
    with open(existing_filename, 'r') as file:
        existing_numbers = [list(map(int, line.split())) for line in file.readlines()]
else:
    existing_numbers =
def generate_new_numbers():
    numbers = set()
    while len(numbers) < 12:
        number = random.randint(0, 20)
        numbers.add(number)
    return list(numbers)
while True:
    new_numbers = generate_new_numbers()
    if len(new_numbers) == len(set(new_numbers)):
        for existing_row in existing_numbers:
            if new_numbers == existing_row:
                break
        else:
            break
with open(new_numbers_filename, 'w') as file:
    for index, number in enumerate(new_numbers):
        file.write(f'#{200 + index}={number}\n')
existing_numbers.append(new_numbers)
with open(existing_filename, 'w') as file:
    for line in existing_numbers:
        file.write(' '.join(map(str, line)) + '\n')
Then I defined an M code to run the program
And in the Gcode file, by calling the file that contains variables #200 to #212, I entered the value of these variables into the Gcode program.
Last edit: 18 Jan 2025 18:06 by Ehsan_R.
18 Jan 2025 18:04 - 18 Jan 2025 18:05 #319301 by Ehsan_R
Now I want to see the created text file in the GUI
How can I do this?
Last edit: 18 Jan 2025 18:05 by Ehsan_R.
18 Jan 2025 21:23 #319317 by Ehsan_R
[code]from interpreter import *
def m456(self):
    import random
[/code]
I changed this part to the code below
def m456(self):
   import random
   import os
        existing_numbers = [list(map(int, line.split(':')[1].strip().split())) for line in file.readlines()]
 else:
    existing_numbers = []
    numbers = list(range(21))
    random_numbers = random.sample(numbers, 12)
    return list(random_numbers)
 while True:
            break
    else:
        break
 index = len(existing_numbers) + 1
    for idx, line in enumerate(existing_numbers):
        file.write(f"{idx + 1} :  " + ' '.join(map(str, line)) + '\n')
    self.execute("#<_random_value_1> = %f " % new_numbers[0], 1)
    self.execute("#<_random_value_2> = %f " % new_numbers[1], 1)
    self.execute("#<_random_value_3> = %f " % new_numbers[2], 1)
    self.execute("#<_random_value_4> = %f " % new_numbers[3], 1)
    self.execute("#<_random_value_5> = %f " % new_numbers[4], 1)
    self.execute("#<_random_value_6> = %f " % new_numbers[5], 1)
    self.execute("#<_random_value_7> = %f " % new_numbers[6], 1)
    self.execute("#<_random_value_8> = %f " % new_numbers[7], 1)
But I get the  error
How do I fix it?
19 Jan 2025 08:30 #319351 by Aciera
But I get the error
What error?
19 Jan 2025 14:51 #319373 by Ehsan_R
Debug file information:
Note: Using POSIX realtime
/home/ehsan/linuxcnc/configs/sim.axis/axis.ini:82: executing 'import sys
sys.path.insert(0,"python")'
PythonPlugin: Python '3.11.2 (main, Sep 14 2024, 03:00:30) [GCC 12.2.0]'
initialize: module '/home/ehsan/linuxcnc/configs/sim.axis/python/toplevel.py' init failed:
File "/home/ehsan/linuxcnc/configs/sim.axis/python/toplevel.py", line 19, in <module>
import remap
File "/home/ehsan/linuxcnc/configs/sim.axis/python/remap.py", line 8
IndentationError: unindent does not match any outer indentation level
Interp ctor: can't instantiate Python plugin
import remap
Python plugin configure() failed, status = -11
iNTERP_REMAP: Python plugin required for python=, but not available:
REMAP INI line:76 = M456 modalgroup=10 python=m456
note: MAXV max: 5.000 units/sec 300.000 units/min
note: LJOG max: 5.000 units/sec 300.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
1978
Stopping realtime threads
Unloading hal components
19 Jan 2025 16:32 - 19 Jan 2025 16:33 #319382 by Aciera
in python indentation is part of the syntax. The line with 'existing_filename = 'random_numbers.txt' needs to be indented by one more space to match the lines above.
def m456(self):
   import random
   import os
Last edit: 19 Jan 2025 16:33 by Aciera.
Time to create page: 0.130 seconds
