Debug file information:
Note: Using POSIX realtime
/home/ehsan/linuxcnc/configs/sim.axis/axis.ini:82: executing 'import sys
sys.path.insert(0,"python")'
PythonPlugin: Python '3.11.2 (main, Sep 14 2024, 03:00:30) [GCC 12.2.0]'
initialize: module '/home/ehsan/linuxcnc/configs/sim.axis/python/toplevel.py' init failed:
File "/home/ehsan/linuxcnc/configs/sim.axis/python/toplevel.py", line 19, in <module>
import remap
File "/home/ehsan/linuxcnc/configs/sim.axis/python/remap.py", line 8
existing_filename = 'random_numbers.txt'
IndentationError: unindent does not match any outer indentation level
Interp ctor: can't instantiate Python plugin
import remap
Python plugin configure() failed, status = -11
iNTERP_REMAP: Python plugin required for python=, but not available:
REMAP INI line:76 = M456 modalgroup=10 python=m456
note: MAXV max: 5.000 units/sec 300.000 units/min
note: LJOG max: 5.000 units/sec 300.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
1978
Stopping realtime threads
Unloading hal components
