- LinuxCNC
- General LinuxCNC Questions
- A Axis creeping - Bias not fixing it - axis not responding to jog buttons
- B.Reilly01
- Thank you received: 24
18 Jan 2025 21:45 #319319
by B.Reilly01
A Axis creeping - Bias not fixing it - axis not responding to jog buttons was created by B.Reilly01
I'm attempting to add a 4th axis to my mill, but I'm running into roadblocks. The axis jogs (but still creeps) under "open loop testing" in PNCCONF. When I launch ProbeBasic, it no longer jogs (while the other axes do), and it creeps at a rate of about 1/2 degree per second. Adding bias doesn't seem to effect it. PID is not tuned yet. When I try to jog it it following error errors out instantly. As you can see in my INI file, I set the following error to 5 degrees to be able to see how fast it was creeping. What are reasonable numbers for accel for a 4th axis?
- Thank you received: 5330
18 Jan 2025 21:54 #319320
Replied by PCW on topic A Axis creeping - Bias not fixing it - axis not responding to jog buttons
if you get a continuous creep, it indicates a problem with feedback.
(backwards, noise generating false counts, PID with no P term etc)
The following user(s) said Thank You: B.Reilly01
- B.Reilly01
19 Jan 2025 00:56 #319329
by B.Reilly01
Replied by B.Reilly01 on topic A Axis creeping - Bias not fixing it - axis not responding to jog buttons
I'm seeing the DRO move with the creeping (that's how I identified the creep), I disconnect the analog output to the drive and it stops, I'm measuring 10mv about on the output to the drive, so the creep is being generated by the control. I tried switching the Encoder direction, no change.
- Thank you received: 7488
19 Jan 2025 02:39 #319340
Replied by tommylight on topic A Axis creeping - Bias not fixing it - axis not responding to jog buttons
Up the P value, check by hand if that stiffens the shaft after clicking on "test".
Are you using the "calibration" from the "machine" menu?
19 Jan 2025 03:01 #319343
With a 10 mv offset and a P gain of 150 it should only take
0.0000666667 inches of following error to zero the bias.
Continuous creeping means an feedback issue of some kind.
If feedback was working, this would cause an instant runaway.
- B.Reilly01
19 Jan 2025 16:03 #319379
by B.Reilly01
Ya'll are great help - I went searching for differences between the axes in the INI and HAL since the encoder switch should have been a major problem and I found that I didn't add the do.pid.calcs to the servo thread for the a axis (addf pid.a.do-pid-calcs servo-thread). Now I got a tuneable axis with WAY too much coast (possibly a drive param issue), but now I have an axis that obeys at least. On to tuning!
- LinuxCNC
Time to create page: 0.266 seconds
