Crush Linuxcnc 9.3
26 Jan 2025 13:00 #319883 by 1240
Crush Linuxcnc 9.3 was created by 1240
Hi
Problem description:
I can load the computer normally and run one
NC Program normally.
(This
NC Program was already being implemented normally)
Machine works normally and finishes NC (turns off spindle)
After that, I can’t run the second
NC Program.
The computer itself does not respond properly to the keyboard I can’t even turn off the computer properly.
If you do not start linuxcnc computer will work normally any long time.
Explanations:
I use google translate
27 Jan 2025 21:15 #319964 by 1240
Replied by 1240 on topic Crush Linuxcnc 9.3
solved
01 Feb 2025 15:01 #320326 by 1240
Before this, I just updated Linuxcnc, and it started working normally.
But after a few days, the problem came back.
Now the computer freezes after running the first NC.
The NC runs completely correctly.
After that, the entire computer freezes. I can't even restart it properly, as it doesn't respond to the keyboard or mouse.
01 Feb 2025 16:28 #320331 by royka
Replied by royka on topic Crush Linuxcnc 9.3
Perhaps the drivers aren't fully isolated from the computer?
Some VFDs create a lot of noise too, mine turned on the lights (with touch sensor) in the living room before I placed a filter for example.
Have you tried to dry run the NC?
Did the PC really crash or just the USB port doesn't work?
Can you reach it vias SSH?
Replugging the keyboard/mouse?
The following user(s) said Thank You: 1240
Time to create page: 0.073 seconds
