Mesa 7i96s spinde out not outing...
- ihavenofish
- Thank you received: 286
26 Jan 2025 23:12 #319917
by ihavenofish
Mesa 7i96s spinde out not outing... was created by ihavenofish
So I've just wired up my new spindle, moves the wires over from the old drive to the new drive and.... nothing.
It seems that the mesa is not outputting any voltage with an M3 command. reads 0 between spindle minus and spindle out. It reads 10v between spindle plus and minus.
The wiring to the drive, and the drive params *seem* correct. the spindle of course works fine in control panel mode.
The DI1 and DI2 pins on the drive are set to fwd and reverse and have the minus on the mesa connected to common and the plus connected to the respective inputs and seem correct.
What have i screwed up here?
- Thank you received: 5330
26 Jan 2025 23:37 #319918
Replied by PCW on topic Mesa 7i96s spinde out not outing...
So you have ~10V between TB2 pins 22 and 24?
Can you post your hal/ini files here?
- ihavenofish
26 Jan 2025 23:44 #319920
by ihavenofish
Replied by ihavenofish on topic Mesa 7i96s spinde out not outing...
Yes. can't post files atm, not on that machine, but they were not changed from the last time. the only change is connecting the wires to the new drive.
I do not *see* any errors.
- ihavenofish
27 Jan 2025 00:46 - 27 Jan 2025 01:09 #319922
by ihavenofish
Oh, A out works now. that was user error. the frequency shows on the drive.
BUT, no turn on. I have the - of the forward run output on the mesa connected to com on the drive. and the + connected to the Di. This is how it was on the delta drive.
Is this potentially backwards? When i read the IO they say 24v when off, and 0v when enabled. so "active low".
Last edit: 27 Jan 2025 01:09 by ihavenofish.
- ihavenofish
27 Jan 2025 01:19 #319924
by ihavenofish
active high vs low no effect.
must be a setting in the drive but i dont see one.
- ihavenofish
27 Jan 2025 01:35 #319925
by ihavenofish
fixed. yay. haha. it was in the wrong mode.
