Mesa 7i96s Is linuxcnc poo poo now,Ive never had to troubleshoot this much.
29 Jan 2025 01:40 #320032 by Mac
Hello
Im new to this forum maybe someone can tell me theirs actually works after waiting weeks for my new 7i96s all it has given me is grief from ethernet driver errors to update errors. tried the newest release didnt work. tried older ones they are poopoo. Do the makers of this software test it doesnt seem like it. Is there any software that works with this board without being a genius at linux. I know im complaining a bit Ive spent days to no avail.Im bald from pulling my hair out.You would think Mesa would test it with linuxcnc.I know linuxcnc used to work now everything is horse menure.
     I was told it started with implementing ipv6. who cares change it back.no matter what i do i cant get any pulses.
29 Jan 2025 02:00 - 29 Jan 2025 02:04 #320033 by PCW
What kernel and Ethernet hardware do you have?
uname -a
will give the kernel version
and lspci | grep -i eth
will usually find the Ethernet hardware
What is the Host PC?
Have you run a latency test?
Last edit: 29 Jan 2025 02:04 by PCW.
  • Platinum Member
  • Platinum Member
29 Jan 2025 02:29 #320035 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Mesa 7i96s Is linuxcnc poo poo now,Ive never had to troubleshoot this much.
Wow Pete, are you Soloman ?
29 Jan 2025 04:51 - 29 Jan 2025 04:52 #320046 by rodw
There can be isuse getting going on newer versions of Linux. This document covers all of the gotchas I know about.
docs.google.com/document/d/1S0K-UBlXnsYC...b_0/edit?usp=sharing
Install the latest 2.9.4 version from the downloads page (released this week) and Follow the relevant sections in this doc once its installed.
Last edit: 29 Jan 2025 04:52 by rodw.
The following user(s) said Thank You: Mac
29 Jan 2025 04:53 #320047 by Mac
I didnt mean to come out punching im just frustrated there is alot to take in. I finally had some progress using an old dell pc pulled out of the garage. got it to load and booted to live install. The issue im having now is during setup of steppers when i go into tune the steppers only go in one direction. the stepper just wiggles a little ccw. cw it spins right up.the steppers are new i tried 2 of them same results. On the display it shows it spinning up to speed no errors but motor just sits there.
29 Jan 2025 04:55 - 29 Jan 2025 04:56 #320050 by rodw
Sounds like its an error with your direction wiring. PLease chaeck it and confirm all connections are solid.
Last edit: 29 Jan 2025 04:56 by rodw.
29 Jan 2025 05:02 #320053 by Mac
Hello
Im pretty sure my new computer is corrupt when i pickup a new one ill implement the fixes you suggested.
29 Jan 2025 05:04 #320055 by Mac
Im checking my wiring now
29 Jan 2025 05:16 #320057 by Mac
Thankyou for helping me I had a switch on the driver set wrong.Im so glad to see something moving.
Time to create page: 0.108 seconds
